Click for Cross Click for Mulder Click for Burger Click for Delta Click for Westport
Inflatable fenders: like? Not like?
Discussion in 'Technical Discussion' started by Danvilletim, Mar 22, 2017.
  1. Danvilletim
    Danvilletim Senior Member
    isleton, ca
    starting to look at inflatable fenders. What do you like or not like? Which brands and where do you buy them?
    They're very nice in a user aspect. Uninflated they fold pretty small and are very light weight which is nice for the user. Sometimes they're too light weight and the wind will blow them around. Not sure which brand is the best these days. They also tend to lose firmness quicker with temperature change than traditional fenders, but in most cases they're an improvement.
  3. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    Quite a few large yachts use them for short-term/overnight berthing as they are light and easily moveable in a new place. Long term, everyone seems to go back to traditional fenders (or in some cases, old tractor tyres :eek:) for home berthing.
  4. Wl3175
    Wl3175 Member
    Newport RI
    Hey we have used AERE fenders on both the Huckins and have been excellent thy come in a range of colors and and the covers are really high quality . A friend uses them on his ocean Alexander 85 and has never had a problem .wouldnt use them if you plan on going through the canal system though .buy regular fenders for that then dump them
  5. Pascal
    They re nice as they take less space but take too long to inflate and deflate even with an electric inflators. Fine on large boats with a lot of crew, not so on owner operated or with just two crews
  6. Wl3175
    Wl3175 Member
    Newport RI
    Hi pascal
    I would agree your statement for the larger ones but we Have them on a 65ft Huckins which is owner operated with - crew which is a family member and they work fine . They do take a little long to inflate with the pump that the supplier suggests .we use a pump for inflating race marks and it's painless .pump is actually smaller and quieter than most .
  7. Ken Bracewell
    Ken Bracewell Senior Member
    Somewhere Sunny
    I'd recommend ProStock over Aere. I've had plenty fail over the years, and the ProStock seem to hold up much better in the seems.
  8. Pascal
    Speaking of pumps. I recently got a small Ryobi compressor which uses the same 18v lithium batteries as their drills and tools. It has both high volume / low pressure for tubes etc and a low volume / high pressure for tires or regular fenders.
    Works really great, no cords etc.
    Haven't tried it yet on the inflatable fenders
  9. ESSRTEE8
    ESSRTEE8 Member
    56 POST in Monmouth Beach NJ
    I use Aere fenders and love them. Wife loves them too, very light, very durable.
  10. chesapeake46
    chesapeake46 Senior Member
    Pascal, did you get the P737, hand held like a drill or the P731 with two different hoses ?
  11. Pascal
    It's the shape of a brick, battery goes in under. One end is low press with a3/4" hose, the other end is high press with standard Schroeder valve and hose
  12. chesapeake46
    Thanks, that's the P731.
  13. ychtcptn
    ychtcptn Senior Member
    Lighthouse Point, FL
    If you are using for long term unattended use, make sure you tie a few weight bags on them. I have seen the small ones blowing out of the way when really windy. I think they are better for short term attended use, as noted before, they tend to lose air in cold weather, reducing effectiveness.
