Click for Walker Click for Delta Click for CL Yachts Click for Abeking Click for YF Listing Service
Inboard Engine Flushing
Discussion in 'Technical Discussion' started by YachtsFanatic, Oct 20, 2019.
  1. YachtsFanatic
    YachtsFanatic New Member
    UAE
    Hello my co yacht enthusiast,
    This should be a short thread. Im just wondering if its possible to do engine flush to rid the barnacles?
    Its for Apremare 29, diesel engine.
    Thanks,
  2. ranger58sb
    ranger58sb Senior member
    Chesapeake Bay, USA
    Generally yes. Look for info on Barnacle Buster or Rydlyme.
    -Chris
  3. T.K.
    T.K. Senior Member
    Cairo - Egypt
    Ofcourse. We do it all the time. I use Rydlyme. It is a fantastic and very effective product.
    Don't forget to remove the water pump impeller when doing the engine flush. You will need to cycle the Rydlyme solution using an external pump for approx. 4 hours inside the engine sea water cooling circuit.
  4. Lepke
    Lepke Member
    I use Rydlyme and think it's great. It works much faster heated (up to 180°F). If you're having cooling issues, you many need to flush the coolant side, too. Take out your engine zincs.
