Click for Abeking Click for Burger Click for Northern Lights Click for Ocean Alexander Click for CL Yachts 99X
Hydraulic thruster pto
Discussion in 'Technical Discussion' started by Matt46post, Oct 15, 2019.
  1. Matt46post
    Matt46post Senior Member
    El dorado hills california
    Hi
    Has anybody had any experience running a hydraulic power unit for a 20-25hp bow thruster off a old Detroit desiel 8v92 main engine ? I have a pair of these in my trawler , I am running a pto off the back of one of the engines for the Niaid stabilizers and was hoping I could run another one for a 12” abt trac bow thruster , it seems with engine running low rpms at idle it would take a large unit to actually power the thruster ? I have Allison trans missions , can I run something bigger off the front of the engine and or gear a pto it so turns much faster? I am also considering running a 220v electric hydraulic power unit with a 20 gallon tank... any advice would really be really helpful
    Best regards
    Matt
  2. rtrafford
    rtrafford Senior Member
    Vero Beach
    Not certain how you're currently plumbed, but I would think that your existing hydraulic pumps for your stabilizers can be the source of your hydraulic supply for the thruster as there would be plenty of pressure, and upon maneuvering speeds your stabilizers should be in a locked position. No need to duplicate the hydraulic pump supply. Just tap into it.
  3. Matt46post
    Unfortunately the stabilizer pumps just don’t put out enough power to run thrusters
    On a Hatteras MY we worked on, The thrusters ran off a PTO straight from the port main crank shaft forward.
    Big asp pump in the shadows.
    The Niaids ran normally from the back of the stb main.
  5. captainwjm
    captainwjm Senior member
    Miami, FL, Cape Elizabeth, ME
    Can’t answer the specific question, but my thruster works off the PTO on my 20 kw genny, stabilizers off the starboard main.
  6. Matt46post
    Thanks for the feed back captainwjm, I have one of the thrusters running off of a 20kw genset and I want to run another thruster so I need another 20-25hp power source, I am looking at running it of the front or side of the main engine, I am unsure if they can gear a pto so it turns 3-4 faster than the engine?
