Click for Burger Click for Abeking Click for Abeking Click for Westport Click for Westport
How warm does the water need to be for the reverse Heat/Air to work?
Discussion in 'Carver Yacht' started by praetorian47, Apr 3, 2012.
  1. praetorian47
    praetorian47 Senior Member
    Bayport, Midland, Ontario
    My boat is going in the water in 2 days and I'm wondering if the heat will work.
  2. captainwjm
    captainwjm Senior member
    Miami, FL, Cape Elizabeth, ME
    Generally above 45 degrees F, although I've gotten enough heat when the water was around 40 - freshwater, if that makes any difference [doubt that it does].
  3. Beau
    Beau Senior Member
    Beaufort, NC
    I've had the same experience here in the NE. 40-45 degrees at the near surface.
  4. Ormond Bert54
    Ormond Bert54 Senior Member
    Ormond Beach, FL
    My understanding is that the reverse cycle takes approximately 7f degrees of temperature from the water. Therefore, as the water temperature approaches 7 degrees warmer than freezing, you are risking freezing up the coils on the reverse cycle unit. So ... 45f and warmer should be safe.
    Mike
  5. praetorian47
    Thanks!
    Now I just have to figure out how warm the water is :)
    I have a depth/temp sensor installed on the nmea2k network I put in over the winter, but nothing is tested yet.
  6. Beau
    Beau Senior Member
    Beaufort, NC
    Praetorian
    Do what I do, just turn it on and see if you get some heat. If not turn it off.
  7. Maxwell
    Maxwell Senior Member
    Door County, WI
    Last April when we picked our boat up in Michigan the water temperature was 36.5 degrees F. The 4 units (2 cabin, 2 helm/cockpit) easily kept the cabin at 72F and helm at 70 without icing up. The air was between 34 and 40F.
    The boat is a Tiara 3900 Sovran with 2 16,000 BTU marine air units at the helm and 2 down below.
    YMMV
    max
  8. praetorian47
    Thanks Maxwell!
    I'm heading up tomorrow and plan on staying for the weekend. I'd like to get some last things ready for the season and it would be nice if it was warm :)
  9. Swamp fox
    Swamp fox Member
    NC
    The system should have a fault that will trip if the coil gets too cold. When I run the heat on my boat, if the I have a valve stick, etc. The compressor trips.
  10. RT46
    RT46 Senior Member
    I have had the reverse air work with water temps down below 40s.
    once the water temp gets much colder it seems to work too hard.
    I have seen a ceramic fan heater blowing hot air on the compressor and coils in in extreme cold weater to help boost the reverse air.
    Im not too sure I like that idea.
    I have had it keep the boat warm below zero as long as the water temps are not too cold. The Air temp donesnt seem to effect the heat output.
    In the winter during low water and air temps, a hot water system seems to be the best way to heat the boat.
  11. Fireman431
    Fireman431 Senior Member
    East central Florida
    You shouldn't have a problem with the water freezing because it isn't static. It's constantly moving even tho it's cooled below the freezing point. Also, the coils will still have heat in the so they shouldn't freeze up in the event it kicks off during it's rest cycle.
  12. praetorian47
    Priming each ac unit's water line was a huge pain. I've never had to prime each unit itself even after the pump is primed, but that's what I had to do.
    Water temp was fine and we had a very warm boat :)
