Click for Perko Click for Abeking Click for Furuno Click for Mulder Click for Northern Lights
How to diagnose PTO issue
Discussion in 'Technical Discussion' started by Danvilletim, Nov 25, 2019.
  1. Danvilletim
    Danvilletim Senior Member
    isleton, ca
    Our port PTO connected to 53kw Mohler is not working. The back end of this gen set was removed and rebuilt and hasn’t worked since. All I know is when selected , nothing works. Suggestions? Who’s the best in Ft Lauderdale to help?
  2. captholli
    captholli Senior Member
    In The Bilge
    What is this PTO running? steering, thruster, stabilizers, davit etc. Does it have an electric clutch or solenoids for on & off / engage -disengage? Could be as simple as a fuse if electrically switched or could be something more. Plenty of all rounders in Lauderdale to work on it. You've had enough hiccups aboard between controls, steering and gens that I would have thought that you'd have found a reliable technical source for your vessel.
  3. Danvilletim
    isleton, ca
    Good info... our engine guy doesn’t like PTOs.. Another company wanted to take it off to bench test it... which is a ridiculous effort before its diagnosed. It’s running thruster, stabs, and windlass.
  4. captholli
    In The Bilge
    So its electrically switched from the helms. Sterling Marine Hydraulics in Lauderdale is a good outfit and its owner Dale has 30 yrs plus of electro hydraulic under his belt. There are many company's as good as Sterling in Lauderdale also but I've used them the last 20 yrs or so and they've proven their worth many times over. Good contractors are always a personal preference.
