Click for Glendinning Click for Abeking Click for YF Listing Service Click for Furuno Click for Northern Lights
How do they match engine size to a boat on paper?
Discussion in 'General Yachting Discussion' started by Pelagic Dreams, Oct 25, 2011.
  1. Pelagic Dreams
    Pelagic Dreams Senior Member
    Land locked for now
    Am I to assume that when a boat is designed that they estimate the size of the engines to the estimated total tonnage the boat will finally be? With the price of fuel as it is and climbing the match in engine size would be critical in making the most fuel efficient vessel.
    Wouldn't hull shape also dictate one engine size over another? This is what scares me when it comes to deciding to take hull #0001 of a completely new build. I could see it being over or under powered and you have a long time headache.
    That's part of a naval architects job is to marry HP with hull size/weight/and design. However, sometimes the builder will build the boat heavier than it's design specs from the naval architect and a once great riding hull, is a pig. Sometimes the manufacturer will take a great proven hull design and get the center of gravity wrong, and make it as wet as a surfacing submarine......etc.......many variables to a good boat.
  3. NYCAP123
    Much also has to do with who manufacturers have a relationship with. Most smaller production boats will give you a choice of a few motors and leave the decision to you (unless you're buying one in stock). One may only give you 2 or 3 extra knots, but cramp your engine room and guzzle fuel, but you choose. For in stock the dealer chooses which package he thinks he can most easily sell or the manufacturer decides based on his commitments.
  4. chuckb
    chuckb Senior Member
    Maine
    :cool:
    Engine size/weight/power is just a small part of the things a naval architect has to balance. In vessels where a single designer handles the tradeoffs, odds are good the end product will be fine. But with multiple designers the opportunity for screw-ups goes up... I've seen weight and balance issues totally deep six a vessels performance due to "the left hand not talking to the right hand" during design. But back to the original question... engine size vs. efficiency. When boats are repowered its interesting to see how many older "planing" boats get repowered to only do 8-12 knots... hull speed cruise with radically better fuel efficiency and reliability. The question you pose is one that inspires kids to try and find the answer... and end up as naval architects. No easy answers... indeed one can make a career out of looking for the answers...:cool:
  5. 84far
    84far Senior Member
    Brisbane, AUS
    The basic thing to look out for is weight. Then you can run your power to weight ratios against other boats/brands. All boats advertise specs on weights (usually half loads).
    For example boat "A" and "B" are the same boat or similar, have the same HP, but boat "B" weighs more - in theory this will cause boat "B" to use more fuel.
    Sometimes going to a bigger HP motor may not have a good effect because they usually weigh more than a less HP motor. This is why the IPS/Zeus are such good systems, usually you can go down a few size in HP compared the usual shaft driven boats, but the boat will run with similar running speeds, BUT better on fuel.
    Hull form is next on the list... but that's another can of worms. and sometimes it contradics the above statement.
    Far
  6. Bill106
    Bill106 Senior Member
    Beaufort NC
    It's all about balance
    Engine selection is one big chunk of the design spiral and also one that usually changes several times during a build cycle as owners/clients change their mind when new engines hit the market.
    Most designers/builders work with a target speed and try and design structure to match the size engine that will provide that speed and build the boat accordingly. Big changes in engine power dictate either increasing structure to handle the larger loads (tough to do on an already built hull) or living with more structure than needed and having a heavier, less efficient boat.
    For an NA or builder, nailing a target speed is usually not too difficult but last minute changes/additions do often cause loss of hair and sleep!
  7. Pelagic Dreams
    Land locked for now
    My area of interest is in a steel trawler design. Cruising speeds of 8-11 knots, twins, but being steel....on the heavy side. My goal is to get 1 Nm of range for every gallon. Hampton can do it on a 65 fiberglass hull, but is it possible on a bulbous bow steel trawler?
  8. Henning
    Henning Senior Member
    Ft Lauderdale FL
    Most definitely. I've long been a proponent of long sleek wave piercing monohulls (look at the Hobie 33), with the new Gyro stabilizer systems you can make them roll comfortable now as well without the drag penalty. Their real advantage though is pitch comfort riding into a sea as you slice trough it rather than pounding into it and surging over it over and over and over again...:eek: These long sleek hulls take less power and achieve higher speeds. Add in a combined cycle steam plant for regenerative heat capture from the prime mover, and suddenly you start getting pretty ****ed efficient. I was also considering solar, wind and tide for electrolysis energy to collect hydrogen for a small fuel cell for water and emergency electric.
    Another nice thing about the design is you get a lot of length and performance in a low volume hull, so costs to build and outfit are 1/4-1/3 of the normal "$1 million a meter" heard quoted for another top name yacht builder for boats over 160'.
  9. Henning
    Ft Lauderdale FL
    Trawler is an inefficient design for hauling passengers. It is meant to haul a large volume of fish, not a few people. Look at the old Sardine Boats rather than Trawlers. Sardine boats ride great in nearly anything and are much faster and more efficient than trawlers.
  10. 84far
    84far Senior Member
    Brisbane, AUS
    Pelagic Dreams, now we're getting somewhere. I would have to say the motor selection is not as important now, and hydrodynamics is. I was thinking you were getting a planing hull.
    If the boat is still in the concept stage (still on the drawing board), I would suggest to maybe pump the length to say 70', and bring the beam of the hull in... or play with the beam's dimensions
    The idea is to get a better "beam to waterline length ratio", and thus improove drag. Is it possible to go to a alloy hull construction...?
    Far
  11. Capt J
    Yes, with a full displacement hull, 1 mpg should definately be possible. The 76' Northern Marine I used to run here and there would get 1mpg at somewhere in the 8-10 knot range, you could cruise it at 12, but it burned more fuel.
    I could get 1.5 GPM at 10 knots on a 75' Hatteras MY, and I also worked on a 97' steel displacement hulled canoe stern MY that also got 1.5 gpm, but this boat was built 25 years ago.
  12. Capt. Mike
    Capt. Mike New Member
    Nashville TN,
    My hull is 103' X 18.5 with new twin 385hp cats @1700 and I get about 1.3 mpg @ 9-12 now if I open her up to 2200 then I will be doing about 15-16
    I am on inland lakes and river and this setup works great. I see most boats my size are about 700hp and some like the hatteras have there boats up to 900hp per engine. I don't think I there going to get 1.3mpg. I would think these big hp boats would do great on the open water but on inland cruising they could find trouble for there wake. I guess this is a bit of the repower trend.
  13. Capt J
    Thats not entirely true.......I ran a 75' Hatteras MY with 12v71 TI's that were around 850hp each. I did the entire Great Loop in the boat, and 90% of the time at 10 knots or less. That boat at 10 knots, burned 13gph so 1.3 GPM, at 8 knots it burned 8gph or less, so 1 mpg. These fuel figures included 1-2 hours at cruise speed of 17 knots/80gph (1/2hr bursts here and there if there was space). Not as efficient as say a full displacement, but pretty darn respectable none-the-less.
  14. Capt Ralph
    Our old 12v71s don't do to bad, but they were not designed to run slow. temperatures and efficiency never come up at low rpm. Most big engines have this problem just the newer ones don't weigh so much.
    In HP selection for a new design, I would consider a low emergency (high) speed for the hull and find a engine that most efficiency (dependable) delivers the designers HP requirements plus a few percent for your hull speed requirements.
    Unfortunately, new emissions and tier levels is forcing about all new engines to be turbo charged. You may need to hurry your design and pre-purchase your mains soon if you want to stay with naturals (if your building in the states).
