Click for Westport Click for Mulder Click for Delta Click for Ocean Alexander Click for Walker
Holding tank
Discussion in 'Ocean Yacht' started by BigChief, Oct 11, 2021.
  1. BigChief
    BigChief Member
    CT
    1996 48 forward holding tank under queen bed.
    The 3 indicator lights for the tank level don't work correctly. The only one that's ever lit up is the bottom 1.
    Does anybody have any experience with these systems and what kind of sending unit might be in the forward tank.
    I know I'm going to have to take the sending out but I would like to know If anyone else has done this before.
    The little floats get stuck most times. The assembly unscrew and up. Have a bucket or pail ready to receive the assembly. Pending tank depth, it could be tall.
    Magnets in the floats open / close lil Reed switches.
  3. Capt Ralph
    If the floats are clear, ohm out the switch. The float / switch kit is available from Dometic.
    I splice in a trailer flat connector to make removing the assembly easier.
  5. 45SS
    45SS Member
    New Jersey
    If it's the same type of sender that my 1997 45 had it doesn't have any floats. I believe it's some type of capacitance set up. On mine the connectors and were corroded beyond repair. I replaced the whole setup with a system from Tech-Edge. Used the existing wiring and the sending unit screwed right in to the existing bung in the tank. Been working good for three years now.
  6. TahoeJohn
    TahoeJohn Member
    Tahoe VIsta
    Another option (if you're considering a full replacement) is from SCAD. I replaced both my holding and fresh water tank sensors with a TM2 - works great.
    https://www.scadtech.com/tank_monitors
  7. BigChief
    BigChief Member
    CT
    Ok thanks I will look I to that before I open or remove what I have.
    Do you have the fiberglass tank shaped like a V under the forward berth?
  8. 45SS
    45SS Member
    New Jersey
    I have a rectangular shaped tank on centerline under master/forward berth.
  9. Capt J
    Yeah, if it's the dometic one it's easy.......they press in, but you have to carefully cut the tubing to fit (use a tubing cutter) and make them the right length. They sell them in the different lengths.
