Forgive me for this boat help in this yacht forum but I have run into a snag now and hoping for some help from some of you. We are installing a new polyethylene holding tank in our little Albin cruiser. The tank has "spin fittings" that are bonded in. The "in & out's" are 1 1/2" and the vent is 3/4" and are standard tapered pipe thread. The fittings I have bought are Marelon male pipe thread to hose adaptors...http://www.forespar.com/products/boat-marine-plumbing- elbow.shtml Being "pipe thread", I thought these fittings would be tapered as well, and work with the tank inserts but they're not. I have tried them in the tank with teflon tape but they keep threading into the tank and don't tighten like I thought they would. I guess these are not the correct fittings to use? What type do I need? Help! Thanks Brian
holding tanks That's odd, I changed 3 gate valves to female threaded marelon and they threaded on real tight with no problems, are you sure the tank fittings are pipe thread for sure ?? hopefully not metric !!!!
The Marelon fittings you have are designed as tailpiece fittings for sea cocks and are indeed straight thread so they will continue to screw in until they bottom the threads. Even with generous amounts of tape or 5200 they will not seal like you will want them to on a holding tank and probably leak odors at best. Most hardware stores carry nylon hose barbs, they are cheaper and will work just fine in this application. (Save those Marelon ones for seacock replacements)
Hi dennismc, Thanks for the quick reply! I have called the tank manufacturers and they say they're standard NPT. The polyethylene is a soft material compared to the Marelon, which makes me wonder if it will just force the tank material "out". I can wind in a 1 1/2" MPT/hose 90 Marelon elbow into the tank by hand all the way in and doesn't tighten. This article from Forespar makes me wonder... http://www.forespar.com/pdf/techTips/M6-Marelon-Understanding-Threadforms.pdf Especially... "A male threaded MarelonĀ® fitting will not work in a female tapered thread". Well, what does one use? They mention their HC sieries fittings but they only go up to 1 1/4" I appreciate any help, thanks. Brian
