Click for Westport Click for Walker Click for Glendinning Click for Westport Click for Mulder
Hi. what is minimum size of ocean cruise?
Discussion in 'General Yachting Discussion' started by P_Bear, Jan 8, 2014.
  1. P_Bear
    P_Bear New Member
    thank you
    Hi.
    I'm inventor at Korea. former software engineer and retired.
    I hope to living at yacht. but in here it's very rare.
    and I hope my home can ship across ocean. Asia to Amercia kind of way.
    IF ship can cross ocean what is minimum size?
    I think it's not matter of size. it matter of toughness. and equipment. but there is something.
    I hope you can advice it to me.
    and I also build my ship by myself and hiring crew. I think CHile is good place to build ship.
    by my knowldege handling fiber glass is just matter of human power so I think I need just 2 skilled engineer to help me. and others Chilean can handle that.
    Thank you for read
    P_Bear.
    You can achieve that a lot easier and a lot smaller with a sailboat. An ocean going sailboat around 40' will do that trip, maybe even smaller. If you're talking an actual yacht, something as small as a 46' Nordhavn or other expedition yacht with the range.
  3. Opcn
    Opcn Senior Member
    The smallest boat to cross the Atlantic was shorter than 2m long.
    Unless you speak Spanish well the easiest place for you to build a boat would be your home country. Being able to communicate well is important.
    You should start by building several boats much smaller than your final boat. Also, your final boat should be built from plans that were drawn up by someone who draws up boat plans for a living.
    Some of what seems like a good idea really isn't. There are many very important aspects of hull design that someone unfamiliar with boats might miss.
    Every year there are people who go out in boats they built themselves. Some of those people listen to experts and build beautiful functional boats. Some of those people scoff at experts, and build their own death traps.
  4. P_Bear
    P_Bear New Member
    thank you
    Thank you I agree.
    but I think language is not big problem. as my experience. at work. language is not the matter. matter is strict to the rule. and I will not conduct people dircetly. I will hire engineer for that. but just 2. I think 2 engineer can handle whole ship building.
    yes hull design must be done by expert. and so I try to hire expert and he will be chilean maybe. or the conduct man will be chilean.
    but I didnt decide. which blue print will be. and first boat which one I will buy. will be small one. of course I hope made it by myself too ..but I think I don't have time for that.
    but I hope build big one. I have some invention for making big structure. automatically building system. like 3D printer . and I want to test it.
    of course. first job after make it is crush it. so it's structure good engouth to trust.
    anyway. I have many ideas.
    If you know about ship building license or work. plz let me know.
  5. olderboater
    You're a software engineer and intend to build a large yacht. Why in Chile? Not like thats the hotbed of boat building. Frankly, if I was a builder or designer I'd take a bit of offense to your belief that it's all so simple anyone can do it. You think a Captain here could design and code an integrated system to cover all areas of software for a manufacturing company in Korea?
    And just your initial question shows you clearly have no knowledge of what you're getting into. The one thing I do agree with is that the first thing upon completion should be crushing it. Perhaps that will keep anyone from getting hurt. I don't mean to be rude but this is just an absurd quest you're talking about.
    Handling glass is just human power? You really think it requires no skill or experience? Well, on that basis, coding software is just human power. There is a tremendous arrogance to think of your own area of specialty requiring expertise but then think just anyone should be able to throw a boat together. Do you intend to build it out of wood and glass over it? Or are you going to create molds first? Any idea how much builders spend in designing a boat and then building all the molds and tooling necessary to actually build it? I'd suggest testing your 3-D ideas on some small remote controlled boats.
  6. Opcn
    Opcn Senior Member
    I similarly don't see why anyone would want to build in Chile.
    If the goal was to build a boat to sail to Chile that would be a desire I could understand.
    P_Bear, I suggest that you consider building in wood and then coating it in Glass Reinforced Plastic (GRP, Fiberglass) to protect and strengthen it. If you are building a big GRP boat the cost of the mold you build it in will be very expensive.
    I don't see as much arrogance as Older Boater sees. I do think that you are probably underestimating the difficulty of building and the difficulty of communicating. Also, when you crush a boat, you destroy it, and you haven't got a boat any more. You intend to test its strength, Olderboater thinks you should probably destroy it.
    When you work on software you and the person that you talk too both speak the language of code. Neither you or your Chileans will speak the language of boat building.
    In any case this is probably not the right forum for you. Yachts come in many varieties. There are plush and luxurious palaces floating on the water. There are bare bones sail racers that fly on gossimer wings. There are hardy explorer yachts with simple sturdy fixtures inside. All of these yachts have one thing in common, they are all made by expert craftsmen.
    If you carry through with your dream you will build a boat, it might be a nice boat, it might be a big boat, but it will probably not be a yacht.
    Boatdesign.net is probably a better place for you to take your questions.
    Also, for his purposes and type of boat that he's looking to build steel would be a lot better building material and easier to do a one off besides, especially in the countries he's talking about. You can also buy plans to successful hull designs out of steel that have been proven and tested over the years. Even then you can take a successful hull design, and severely screw it up making it totally unsafe at sea, by getting the COG wrong or weight and balance wrong. Building a yacht is not like putting Lego's together.
    I too agree that building a yacht is definately not an easy endeavor and that this is not the right forum for the OP.
  8. K1W1
    Whats with the Chile bashing here today?
    There are undoubtedly yards in Chile that can build yachts just like anywhere else.
    Not everything happens in the contiguous 48.
  9. olderboater
    When I questioned Chile, I wasn't bashing Chile, just was surprised at that choice as he's in Korea presently. I wasn't thinking in the U.S. I was thinking of Korea, itself, and all those places closer. There is a lot of boat building expertise far closer than the Americas. And also I am not aware of any boat builders in Chili. Few in South America but the ones I'm aware of are in other countries. So, Chili seemed a bit of an odd choice unless there were some reasons we were unaware of. Are you aware of yards that build boats in Chile? I'm aware of some in Brazil and Argentina.
  10. K1W1
  11. Opcn
    Opcn Senior Member
    You've misunderstood me. There are undoubtedly Chileans who can build great boats. I do not get the impression that he intends to hire them in particular.
    It's not bashing Chile to suggest that a particular trade is not known by all the men of the country.
    As a proud Alaskan I would never suggest that things only happen in the lower 48.
  12. Old Phart
    Old Phart Senior Member
    I dunno
    Asenav Shypyard - Products
    ATMOSPHERE - Passengers ship: current position and details | IMO 9401001, MMSI 725015400, Callsign CBTM | Registered in Chile - AIS Marine Traffic
    Expedition motor yacht ATMOSPHERE -
  13. K1W1
    Rather well stuffed (full)that one is.
    150ft, 28 guests and 32 crew according to the Charter site
  14. Old Phart
    I dunno
  15. Chapstick
    Chapstick Member
    Sydney
    That seemed to be an unnecessarily harsh post....
    The OP doesn't seem at all arrogant to me, and people have succeeded at stranger or more impossible quests than this one.
    I don't think he's claiming to be able to do it himself anyway: he clearly stated he plans to hire "engineers" to do the building or designing.
  16. ArielM
    ArielM Senior Member
    Los Angeles
    i agree with chapstick. English is clearly not the OP's first language and a lot can be lost in translation. For one i didn't read anywhere in his post that he plans to design/build this boat on his own. he actually specifically states that he plans to hire an engineer (aka naval architect) to design the boat for him. And for all we know he might actually intend for a qualified yard to have the boat built.
  17. P_Bear
    P_Bear New Member
    thank you
    Ah
    I'm not happy with his words but in Korea. it's much more worst. anyway I consider he show good intentions.
    Korea is not good place making small yacht. in Korea there is no small yacht company.
    no culture. nothing similiar like that. and why he think I don't know about Korea?
    and why I don't know about material difference about Wood and steel and FRP..
    so.. main problem is the money. nothing else. and Chile's weather is great. minimum wage is just 400$.
    and sorry to mention. by my expert area. 3D software engineering is much more complicated than boat building and I'm world class about my experty. I even made my own 3D modeling software.
    so I can handle engineering data. but I have no experience. that's all. and It's not my job. my crew's job.
    anyway. arguing about Am I dumb or not is not matter of all of us.
    all you people was so rude. but I'm not acusing anything. so I'm better than all who accuse me.
    I think. keep visiting this site and some regional member will make me fiss off. there always some low level people he is better than others.
    P_Bear.
  18. P_Bear
    P_Bear New Member
    thank you
    Thank you so much. and thank you for stopping that kind of behavier. can I ask your location?
    I plan to settle at US. within several years. and I think. it could be matter of my nationality. so I must not go to florida and alaska.
    Anyway. nice to see you.
    I'm former world class 3D software engineer (game , CAD, so on) and now I'm inventor. I'm focusing on 3D printer Area.
    P_Bear.
  19. Opcn
    Opcn Senior Member
    3D modeling may be more complex than boat building (boat design uses a lot of 4D modeling, which is 1D more complex than 3D modeling). However, that doesn't have much baring on the issue. It's not that anyone thinks you cannot handle the complexity eventually. It's that no one has ever been born who could handle it without a lengthy learning process.
    Korea probably has more ship builders and more boat builders and more locally owned yachts than Chile. The point about the materials was not the material qualities, but the build process. GRP lends itself well to building multiple hulls, because there is a one off plug and mold cost.
    The minimum wage is lower in Chile, but you will not be paying that if you are paying boat builders.
    As to Chile being warm, Most of northern Chile is high desert, with a very narrow strip of very valuable flat land right next to the water. The prevailing wind off the ocean keeps the winters mild, but at the latitudes you are likely to end up (further from the equator than you are now) you are going to experience some cool winds in the summer too. Patagonia is beautiful though.
    Have you considered China? It's near by, better industrialized, better supply chains, lower wages, south china is warmer, there is more yachting culture in China than in Chile or Korea, more shipyards, more expertise. You are also more likely to find linguistic common ground that makes projects like this work so much better.
  20. P_Bear
    P_Bear New Member
    thank you
    NO thank I have brain. and mine is very good.
