Click for Cross Click for Burger Click for Burger Click for Abeking Click for YF Listing Service
Headliner needs help
Discussion in 'Technical Discussion' started by MBevins, Feb 21, 2019.
  1. MBevins
    MBevins Senior Member
    Windsor On. Canada
    The headliner on my center console was coming away from the fiberglass structure and quite frankly was looking pretty bad so I had upholstery guy come in and replace it.
    A month later the glue that held it in place was letting go and it was sagging.
    In my usual style and grace i cursed him for using a subpar glue and went about regluing it myself.
    I used 3M 77 adhesive, it's my go to product for spray adhesive.
    Yesterday I opened the door and the headliner was down again. It lasted a grand total of 2weeks.
    So now I have a problem, why is the glue failing and what glue is the solution.
    I have a feeling that the heat might be a problem, it's under a mooring cover and SW Florida isn't the coolest environment.
    Any solutions from the Brain trust ?
  2. RER
    RER Senior Member
    Newport Beach CA
    Without a photo I would take a guess and say replace it with a solid surface product like starboard or high pressure laminate held in with screws or trim. You'll never have to mess with it again. But again I can't see what you're dealing with.
  3. MBevins
    Windsor On. Canada
    I thought of that but it's a compound curved surface so any hard sheeting is out of the question.
    What ever glue that the manufacturer used lasted about 10 years .
  4. justold
    justold Member
    new jersey , fla
    If you used 3m77 for head liner you went from sub par to sub sub par total wong product for the job . You need a high heat adhesive such s Dapp landau top and trim adhesive , 3m also makes a product for this application . The problem now s you have to remove all the old adhesive because it s the weakest link .
  5. MBevins
    Windsor On. Canada
    That's what I was thinking as well.
    I found a product..polymat 797 that appears to be ok. Ever heard of this product? I'll check out the one you suggested as well
