Click for Abeking Click for Ocean Alexander Click for Perko Click for Westport Click for Glendinning
Golf Cart Batteries
Discussion in 'Technical Discussion' started by aircar, Oct 20, 2016.
  1. aircar
    aircar New Member
    Lewisville, Texas
    I have 12V71's on Hatteras 61. Can I replace the house battery banks with golf cart batteries? Largest I can find are Trojan T-9's. The banks are used for starting, powering bilge pumps, heads, monitoring system, some lighting. I use generator if anchoring out.
  2. Pascal
    I be used four 8V exide golf cart batteries on my 53 with 8V71N and they crank just fine. I know others who use them with 8V92T
    Not sure about the 12s
    It depends, is your Hatteras a 24 volt boat or a 32 volt boat. If it's a 24 volt boat, no you cannot use golf cart batteries.
  4. Pascal
    Why not? For house purposes y can use four 6 volts or three 8 volts to make a 24 v house bank. I'd prefer the 8 volt batteries as that would be one less connection.
    For cranking, I m not a big fan of not having dedicated start banks. On larger boats there is no reason not to have dedicated start banks. I know you re almost always on Genset but all it takes is the charger shutting down to run down the bank shared by house and start. And even with a parallel solenoid as a back up it s less than ideal
  5. Capt Ralph
    We use the East Penn 19" 8V batts for our 32volt ship & 12V71TIs.
    Two banks. Each starts it's main engine and runs half the boat.
    Factory set up. Works like a champ. Twice a year water levels are checked and added to.
    Once a year each cell gets tested and the batts get carbon pile load tested.
    On the average, they last 4 years before any loss of performance is noted. They could go 5 or more but once they start loosing any umpah, you never know when they will fail completely and strand you.
    I have added some 24Vdc taps;
    The 10KW radar draws it's 24Vdc from third batt on the port bank.
    Some other 24Vdc options are tapped off the stb bank.
  6. jkotler
    jkotler New Member
    huntington,ny
    I replaced both banks with the Trojans this past spring and couldn't be happier. They're
    easier to deal with and the motors start without a problem.
    The charging profiles are different (voltages) between the 8 volts and 12 volt batteries. The Deka distributor explained it to me once, but 3-8 volts have a higher resting voltage and charging voltage, and a 24 volt charger or alternators doesn't charge them properly and they lead a much shorter life.
  8. Capt Ralph
    Hummmm
    We are all talking about flooded batteries here I thought.
    Better golf cart batteries designed for rapid cycles can take a high rate of recharge. As much amps as the wire can carry up to 2.4V (or more) per cell.
    The float or finished maintenance charge on near all flooded batteries end up around 2.15 to 2.20 Vdc per cell.
    6, 8 or 12v batteries flooded carry the same chemical characteristic, some can discharge or re-charge at different amperage's, the end result per cell is near the same.
    With this simple rules in my mind, your statement confuses me a bit. Can You explain further?
  9. Capt J
    I can't as I cannot remember exactly what they told me, but they told me not to do it. They mentioned charging and resting voltage etc.
  10. Pascal
    Odd. Charging profiles vary depending on the type of battery but for lead acid each cell is usually 2v The 8v batteries have an extra cell. It's no different from the rolls batteries which are made up of individual 2v cells tied together externally
  11. chesapeake46
    chesapeake46 Senior Member
    Call that dude back and ask him to elaborate !
    I appreciate all your inputs but you need to start taking notes !!
  12. Capt Ralph
    Aircar
    Is your ship still 32v or 24v? What cranking amp spec does the T9 battery offer?
  13. dainisk
    dainisk Member
    Perth, Fremantle
    I have been using 6 Trojan T105's for years now, arranged in series/parallel for a 12V system. I do have separate starting batteries, but the Trojans will happily crank as well. The last bank lasted 7 years before one cell failed. Before that it was about 5 years (I think). Just need to top up the water every now and then.
