Click for Westport Click for YF Listing Service Click for Abeking Click for Walker Click for Burger
Glendinning auto pilot acting up
Discussion in 'Luhrs Yacht' started by Joe McKairnes, May 24, 2021.
  1. Joe McKairnes
    Joe McKairnes Senior Member
    lacey twp NJ
    ran 3 hours on AP and everything was fine until about 2 minutes from home port - Port engine revved up, then went to almost idle - Starboard engine stayed fine (master). tried a few times - same issue...
    Any thoughts as to what is causing this?
  2. MBevins
    MBevins Senior Member
    Windsor On. Canada
    It's actually your engine synchronizer. They're basically mechanical so first things first, check all the linkage points on the unit. Then the engine linkage.
    If that's all good check back for further instructions.
  3. Joe McKairnes
    lacey twp NJ
    I checked the 90 degree joint at the engine, greased them. Then disconnected each tach cable... they turn freely.... anything else I should check?
  4. MBevins
    Windsor On. Canada
    Did you inspect the actual unit?
    Baring any linkage issues at the unit, your best to call Glendenning's service department. They are extremely helpful and might be able to point you at a particular item.
  5. YachtForums
    Glendinning notified. :)
  6. MBevins
    Windsor On. Canada
    Thanks Carl.
  7. Joe McKairnes
    lacey twp NJ
    Thank you all! I did send a note in... awaiting response..I really do like the unit.. hoping to figure it out as I have some long offshore runs coming up!
  8. Joe McKairnes
    lacey twp NJ
    This forum is the greatest!!
  9. Robertoman
    Robertoman Member
    San Diego
    What was it?
  10. Joe McKairnes
    lacey twp NJ
    Still troubleshooting...
  11. CGlendinning
    CGlendinning New Member
    Myrtle Beach, SC
    Hi Joe- I just spoke to Rick our Synchronizer guru here at Glendinning and he told me he is currently troubleshooitng your unit. Hopefully he can help you find a solution shortly!
  12. Joe McKairnes
    lacey twp NJ
    You guys are great..appreciate the help... great company... great product!
  13. Joe McKairnes
    lacey twp NJ
    turns out the failure was at the 90 degree adapter at the front of the Yanmar engine. Got a new one coming.... man I miss this great feature!
