My 2008 Carver Mariner galley window leaks due to the outside water pressure. Cabinets continue to get wet even after I tighten window tabs. Any suggestions?
I frequently clean the drain slots in the lower window frame with some mechanic's wire or the tip of a medium sized cable tie. You would be surprised how much crap you can wash out of the slots with a little water and some prodding. Try that.
