Click for Westport Click for Abeking Click for CL Yachts 99X Click for Ocean Alexander Click for Abeking
Galley Sink Attachment _ 290 Tournament
Discussion in 'Luhrs Yacht' started by Marc Anderson, May 26, 2020.
  1. Marc Anderson
    Marc Anderson New Member
    Maryland
    The plastic elbow joint fitting is cracked under my galley sink. Does anybody know where I can obtain a substitute part or improvise a work around? No luck at West Marine or local hardware store.
    Are you talking about the P-trap (from the drain)? If so it should be a standard plumbing item found at your local HD.
  3. Marc Anderson
    Maryland
    I don't think so. I'll post a picture of it.
  4. Josh Keeran
    Josh Keeran Member
    Chicago/Racine,WI
    Not exactly sure what you are referring to but my 2000 Luhrs has all Pex type water lines. I had to cap the plastic water line going to my old ice maker location. I used Shark Bite or a similar product used for pex tubing which I found at my local hardware store.
  5. Josh Keeran
    Josh Keeran Member
    Chicago/Racine,WI
  6. NYCAP123
    Is this "elbow joint fitting" on the drain, the waterline or a cabinet support? Is it a Pex line or PVC? A pic would help.
