Click for Perko Click for Burger Click for Abeking Click for Westport Click for Nordhavn
Fuel truck delivery - Richmond, CA
Discussion in 'Marinas & Waypoints' started by TahoeJohn, Feb 3, 2021.
  1. TahoeJohn
    TahoeJohn Member
    Tahoe VIsta
    I'm looking for fueling options in the San Francisco Bay area, and I'm finding that fuel truck delivery doesn't seem to be as popular here as it seems to be in the Southeast.
    However, I am working with a company who is willing to quote me, and we're looking for a location at which we could perform this fueling. Does anyone know of a public dock in the Richmond area where I could pull up with my boat and they could get relatively close with their fuel truck?
    Thanks!
  2. Capt Cole
    Capt Cole Member
    Pittsburg CA
    I am assuming your boat is larger than the typical size cruising the S.F. Bay. I would suggest calling one of the local marinas such as Schoonmaker Point or Clipper Yacht Harbor for suggestions. You may also try KKMI Boat Yard in Richmond or the USCG Station San Francisco for advice. There are several marinas in the Bay Area with fuel docks, but I suspect you need accommodation for a larger vessel or several thousand gallons of fuel.
  3. TahoeJohn
    TahoeJohn Member
    Tahoe VIsta
    We're a 76' boat and looking for ~1600 gallons, so not a huge amount of fuel, but enough that I'm trying to find a more economical source than the ~$3.50 I'm generally seeing from marinas. My assumption is that a marina with a fuel dock would not be very accommodating to a fuel truck delivery service, which of course is bypassing their own desire to sell you fuel.
    Good suggestions to check with boat yards and the Coast Guard, as we'll have to notify the latter of this event, regardless. Thanks!
  4. olderboater
    Are you planning on staying overnight at the marina you choose? That would generally be expected or they'd charge a fueling surcharge. Often times a commercial dock is your best option if just fueling and going.
  5. NYCAP123
    The cheap can get expensive between getting there and back, the cost of dockage, etc. Also make sure you have sufficient oil pads to clean up any spillage as I doubt that will be well received in Ca.
  6. gr8trn
    gr8trn Senior Member
    OR/CA
    So... how much do you plan on saving the gallon with this process?
    Find out where the fishing fleet, tug and pilot boats go too.
  7. TahoeJohn
    TahoeJohn Member
    Tahoe VIsta
    Not sure how much I'll save, maybe $800 or so. Not a life-changing amount, but after a few fill-ups, maybe it's worth it.
    I'm also looking for a faster-flow solution, as my marina's small hose would take quite a while.
  8. TahoeJohn
    TahoeJohn Member
    Tahoe VIsta
    I wasn't really thinking a marina, as I'm assuming they would all prohibit me from by-passing their own fueling option. Agreed about a commercial dock. Hoping that someone with more local knowledge than me has perhaps already done this and could point me to the best spot.
  9. olderboater
    You might contact Diesel Direct. They should be able to help you.
  10. TahoeJohn
    TahoeJohn Member
    Tahoe VIsta
    Yup, you nailed it... that's whom I'm working with.
    I think I'm dealing with a relatively new employee and I've asked her to talk to others there to see what spot they've used previously.
  11. gr8trn
    OR/CA
    Two valid reasons.
    As you say, you will need a place where the truck can pull up and be adjacent to the boat. I vote for Pier 39. Gice some of the sealions a run for their money. Tourists will love it. ;)
  12. Capt J
    Many marinas will discount on that type of volume, so ask marinas first, then find out where the commercial guys are filling and call there as well, and see if there are any fuel trucks. Unless it,s over $0.50 a gallon I wouldn’t bother.
  13. NYCAP123
    DK how it is in Ca. but I've seen this done in many places on the east coast although I can't remember many boats that did it on a regular basis. Maybe they did it once or twice and decided it wasn't worth the risk. Just be aware of the pitfalls and be willing to accept the risks. 1) Unknown quality of fuel. Word goes out fast when a marina sticks bad fuel in a few boats and there's a tankful to check to prove damage. Not so with a truck. 2) Liability if there is a spill. Marinas have insurance to cover fines and cleanup costs. Does the truck or will they just disappear in the event of a spill, leaving you to hold the bag? If you go to a fuel dock that services larger vessels (50'-60'+) you'll generally find a high speed pump (although not the speed you'll get from a truck, but that's a double edged sword). You'll also find that they generally offer a volume discount and over 1,000 gals will certainly qualify. Also consider the fuel you'll burn getting to and from where you go to fuel. Most of the boats I've seen fuel from a truck did so at their slips or in some situations the berths over in Port Everglades. I wasn't involved with the business end there, but I'm sure they paid a fee for that.
  14. Capt Cole
    Capt Cole Member
    Pittsburg CA
    I have never seen it done anywhere in the SF Bay area. If you are coming from the South, stop at Pilar Point Marina and fuel where all of the fishing boats do. If coming from the North, Bodega Bay is your best bet. You can call them and get accurate pricing with some discount for the quantity you mentioned.
    In my 30 plus years running boats in SF Bay, I've never seen anyone using a fuel truck. Did see it one time in Morro Bay where a ship took on around 20K gallons
  15. Oscarvan
    Oscarvan Senior Member
    Chesapeake Bay
    He HAS found a fuel truck. He's looking for a place to tie up where the truck can get to him.
  16. T.T.
    T.T. Senior Member
    S.F.
    Fishermans Wharf has a big dock and a big nozzle and cheaper fuel. Call them for hours as I know the Port is doing some work around there
  17. Capt J
    and their lies the entire problem. A fuel truck that generally fuels yachts will know where to tie up. Doubtful in San Francisco there is such a place!!!!!
  18. olderboater
    Well, we do it on a regular basis and know of hundreds of boats that do. There are many highly reputable fuel trucks and fuel boats in South Florida and they are welcomed at quite a few docks.
    As to San Francisco, we fueled at a commercial dock rather than from a truck, with the fuel supplied by a local fuel distributor, not a marina situation.
  19. AnotherKen
    AnotherKen Member
    Canada
    If a dock wasn't available I have heard of tender services operating in the Pacific, so it might be worthwhile to check out their prices.
  20. Rusty Mayes
    Rusty Mayes Member
    Sanfransico Bay area
    Call Ramos Oil in Fairfield, I talked to them a while back and know that they do dockside fueling. They should know which docks they have access to. I can ask a friend that runs a marine services operation in the bay and he may have an idea or even a dock you can use.
    Rusty
