Click for YF Listing Service Click for Cross Click for Ocean Alexander Click for CL Yachts 99X Click for Northern Lights
Fuel Tanks
Discussion in 'Luhrs Yacht' started by Just Fishing, May 10, 2021.
  1. Just Fishing
    Just Fishing New Member
    Matagorda, TX
    All,
    I am still working out the kinks of this old girl. 1993 380 Tournament Open. I have got to take her out the other day for a good old sea trial. Before I bought her, I knew she had the saddle tanks removed before. I was assuming that the main tank was much larger than it is. So what size was the main tank? I ended up measuring the tank and came up with about 350 gal. I then run the tanks down to almost nothing. 2" off the bottom. I could only get about 280 gal in the main tank. A real shocker. I need more fuel on the boat.
    • So does anyone have the original measurements for those saddle tanks?
    • How were the fuel lines run?
    • What kind of fuel usage should I expect out of the 6-71 Detroit?
    • Does anyone have a fuel curve?
    • If I get a fuel bladder, does anyone know how much weight the bow might handle?
    You might want to send a PM to Andy Sav. I believe he recently bought the same boat. Might have some answers for you.
    What HP and brand of detroits do you have? You need that in order to get a proper fuel curve.
  4. Just Fishing
    Matagorda, TX
    Thanks, NY Capt. I will do that.
    Capt. J, I have the 6-71 485hp I believe.
