Click for Nordhavn Click for Delta Click for Cross Click for Abeking Click for Burger
Fresh water tank shut off valve
Discussion in 'Bertram Yacht' started by TravisBobby, Apr 25, 2024.
  1. TravisBobby
    TravisBobby New Member
    Riviera Beach Florida
    where is the fresh water shut off valve located on bertram 28
  2. TravisBobby
    I filled up both of my water tanks and when I went to turn on the water pump nothing came through it so I was wondering is there a shut off valve that's stopping it from flowing through
  3. chesapeake46
    chesapeake46 Senior Member
    Does the pump run ?
    If it runs, does it need to be primed or bled of air ?
    Was the boat winterized ?
    is your bilge pump running more than usual ?
    Can you see or trace the water lines from the pump to the tanks ?
    I don't have a Bert so I don't know your system.
    My system has no valve between the tanks and the fresh water pump and I can clearly see my water lines in that area.
    Capt Ralph likes this.
  4. SplashFl
    SplashFl Senior Member
    S. Florida _ Bertram 46
    Until I added one; from the factory my previous 38 did not have one. Newer 46 has two tanks joined
    with a connection pipe that has a valve. Does yours have one of those extremely overpriced Jabsco Par diaphragm pumps ? If so, I found them extremely unreliable. If you remove the intake hose on the pump is there water ?
  5. Capt Ralph
    If it says Bertram, I do try to be involved.
    My brothers beat me to this post.
    They are,, as usual ,, on it..
    I can next guess, this is a new to you boat??
  6. TravisBobby
    The pump runs but no water comes out this pump looks like a mini air compressor with a gage lol
  7. Capt Ralph
    And it worked last when?
    Update with a 600 pix picture of the pump.
    Tell us about multi water tanks.
    Tell us you followed the water hoses and what you found.
    Tell us you left the spigot open when the pump was open.
    Tell us something to go on,, to help...
  8. SplashFl
    One of the no water times it turned out the outlet fitting that was screwed into the bottom of the tank was clogged with some white crystal like stuff. Another time that same stuff was messing with the pump so I added a water filter. Never found what the stuff was so figured it may have been something in the city water reacting with the aluminum tank. Current 46 has two aluminum water tanks but not had that issue.
