Click for Nordhavn Click for Northern Lights Click for Walker Click for YF Listing Service Click for Westport
Fresh water pump
Discussion in 'Technical Discussion' started by Fdemelo, May 31, 2016.
  1. Fdemelo
    Fdemelo New Member
    Massachussets
    HI
    I have a 2003 52' tiara with a water pump problem. don't know if its because of the water pressure at the dock but its leaking at every connection and it wont pump water when im not hooked up.
    any ideas what it might be?
  2. Maxwell
    Maxwell Senior Member
    Door County, WI
    I believe that boat has some sort of expansion tank in the system. The fact that its leaking at every connection when hooked up to dock water would tell me that it can't build the pressure enough to actually pump water to the faucets on its own. I'd suggest fixing all of the leaky fittings and try again.
    max
  3. Lepke
    Lepke Member
    If you have leaks on the suction side, it's easier to suck air than water. So the pump can't pull water because the air pulled into the suction plumbing breaks suction. If shore water flows thru the pump, the leaks could be from excessive shore water pressure. My water connection to shore comes after the pump, so the pump isn't used in port unless I am running off the tanks.
    As above, fix the leaks. Take a pressure reading of shore water. You must have an expansion tank after the pump. Make sure the bladder pressure is correct. Opening a faucet can help the pump get initial suction.
  4. ranger58sb
    ranger58sb Senior member
    Chesapeake Bay, USA
    Our pump isn't in use when we're hooked up to a dockside water supply.
    If it won't pump from the onboard tanks... without regard to leaks... could also be a failed pump... or failed electrical connections... or a failed breaker... or a breaker not turned on...
    Our freshwater pump only has two connections, an innie and an outie.
    It happens ours are the QEST snap-in connectors; if those are loose (un-snapped) for some reason, the connection isn't sealed. If your pump has those kinds of connectors, check to see they're fully inserted into their track.
    Or... another style of connection can be simple hose clamps. It should be easy enough to see if those are tight.
    -Chris
  5. Txcruiser
    Txcruiser New Member
    Texas
    Maybe I am missing something but if you are connected to dock water the onboard pressure water pump will not operate. It is intended to pump only when disconnected from shore water. I just replaced my pump with a new Johnson variable speed pump that is a little higher capacity and pressure. I don't have an expansion tank. Bought the pump on
    Amazon.
