The more knowledgeable heads on the forums can guide this thread. I believe the current 56-meter Feadship "Broadwater" that just had the extensive refit in 2019 through to 2020 is the ex. "Rasselas" built as a 52-meter all white finish with a rounded stern. If it is the same vessel, her appearance now is remarkable, the amount of work that was done. Not only was she lengthened and the rounded stern changed and lengthened and turned into a more modern stern the mast was altered, hull colour changed and interior redone. Of course a tonne of other technical works were carried out too. I believe her refit was done at Huisfit.
