Click for Glendinning Click for Abeking Click for Furuno Click for Ocean Alexander Click for Mulder
FD long range cruiser from De Vries Lentsch
Discussion in 'General Yachting Discussion' started by Santelia, Sep 24, 2011.
  1. Santelia
    Santelia Member
    La Maddalena, Porto Santo Stefano, Grado.
    Hi all,
    among other choices I'm considering the purchase of an old 49' long range cruiser from De Vries Lentsch, full displacement steel hull with round stern, raised pilothouse and portoguese bridge. No upper sundeck neither flybridge at present, so also planning to add them.
    Anyone has experience on such vessels?
    Much roll and pitch witout stabilizers?
  2. AMG
    Hi, hard to answer without knowing the boat, but if you add something on top, it will probably roll a lot...
  3. JWY
    JWY Senior Member
    Sounds like you're describing a Lowland. If so, great yacht, classic design, elegant cabinetry, beautiful aesthetics. Your additions will change the profile and appearance as well as the weight above water line.
    Judy
  4. Santelia
    Santelia Member
  5. nilo
    nilo Senior Member
    Istanbul
    being a canoe stern she will definitely pitch more than today's designs. i would second lars and will recommend that you should not consider to add an additional level; unless you do a very through engineering. i doubt you will be able to obtain the initial stability calculations; so it would not be an easy task!
  6. JWY
    JWY Senior Member
    No disagreement, Nilo, but I would like to add a clarification. There are modern canoe stern designs that do not pitch.
    Judy
  7. nilo
    nilo Senior Member
    Istanbul
    underwater hull design
    of course judy; pitching is due to the underwater hull design of these old boats.
  8. Santelia
    Santelia Member
    Hard to believe that adding a handrail and the light weight of a helmstation and a couple of settees can have a significant impact on stability. Nohing that cannot be easily corrected, for instance, by adding a small tank at bilge.
    As far as "old" canoe stern behaviour is concerned (never heard of "new" canoe stern), do you think that adding a large structural swimming platform at water level can decrease the pitch rate? Just to add a point, is well known that canoe stern is the best boat end to decrease turbolence in pure displacement water flow.
  9. K1W1
    As whatever you are going to add to the top of the boat will be kind of permanent it might be cheaper and easier to add some fixed ballast low down.
    You will be best off to have someone competent do some calculations or you might well become a statistic like these guys did.
    The report makes some interesting reading in regard to the effects of multiple additions and alterations.
    http://www.uscg.mil/hq/cg5/docs/boards/amerialtair.pdf
  10. JWY
    JWY Senior Member
    Santella -- a naval architect or marine engineer can best answer your questions, but you have had professionals here all comment that the added weight on the upper deck will most likely affect stability. Perhaps you're right in that it doesn't "sound" like that much weight. So lay it out: take some stainless rails the length you will use, then take some wooden boxes the size of your seating, and helm, then take a scale and weigh out the electronics, controls, and gauges you would install. No bimini? Don't forget the miscellaneous like cushions, wiring, and six-packs. And then body weight - if you have Europeans that might only be another 250 lbs for 2, but if Americans, that can add on another 400 lbs before lunch.
    Canoe stern models such as Sea Spirit Passagemakers didn't just add a swim platform, they had an established naval architectural firm design an appropriate hull form. The Cheoy Lee 66 long-range cruiser was a canoe stern that was reformed as the Serenity 68 with more changes than just the addition of a swim platform with particular engineering to reduce the weight above waterline.
    I recommend professional help.
    Judy
  11. Santelia
    Santelia Member
    All interesting replies and considerations.
    Surely I'm not going to add anything without a proper engineered project.
    Very interesting the report in the link too.
  12. JWY
    JWY Senior Member
    Please let us know if you proceed with this purchase and subsequent project. I know we would like to hear a happy ending and how you got there.
    Judy
  13. david_japp
    david_japp Senior Member
    london
    hi
    she will certainly roll without stabs but rolling is something you can get used to. stabs can be retro fitted as we have done to our 62ft 1961 Van lent built round-bilger ...what is the boat you are contemplating buying?
  14. NYCAP123
    It looks like you're talking about a boat weighing 40-50,000 lbs. The conversion you're talking about could easily put 2,000 lbs. or more up top with your guests. That's significant. Roll stabilizers will certainly make cruising more comfortable, but I think adding ballast is most important. Should anything happen to the stabilizers you could be in real trouble. Definitely have a professional look at it.
  15. Wolf Hound
    Wolf Hound New Member
    Indianapolis, IN, Holland, MI, and Dover, DE
    Thank you, K1W1.
    The report you attached is well worth reading.
    The principles involved, although on a smaller scale (with consequently smaller margins for error) also apply to pleasure vessels.
    Many ignore stability calculations because of the complex mathematics involved--- it's easy for eyes to glaze over.
    There were many fairly straightforward rules of thumb used by 19th century shipmasters, of which one side of my family was largely comprised.
    The old sailing ships of course used moveable ballast, particularly when sailing light, of stones or pig iron or brickbats (or whatver was heavy and handy and cheap) so our circumstances are different, but perhaps applicable modifications of some of these old rules could be developed.
    I heard a few of these rules cited by a great uncle when I was a young boy, but I'm afraid they're now lost to my memory...
    Wolf Hound
