Click for Burger Click for Delta Click for JetForums Click for Westport Click for Glendinning
European discharge regulations
Discussion in 'General Yachting Discussion' started by cabobo09, May 18, 2011.
  1. cabobo09
    cabobo09 Member
    Cabo San Lucas
    My boat only has a black water tank with all sinks and showers discharging overboard. I understand discharging gray water directly overboard is not allowed in Europe. Can anyone provide the rules while cruising in the Med. Does it vary depending on country and marina. Thanks
  2. AMG
    I have heard it discussed, but I donĀ“t think it is generally regulated.
  3. cabobo09
    cabobo09 Member
    Cabo San Lucas
    There is actually some pretty good info that was posted on YF but did not come up until I Googled it. Seems it is a "gray area". Anyone in Europe with first hand knowledge would be appreciated.
  4. K1W1
    Your needs to comply with Marpol Annex IV will depend upon your vessels size.
    You will find that in most busy marinas after dark there is an over powering stench of turds as a synchronised black tank pumping takes place, St Tropez is a good example of this closely followed by Monaco.
    Personally I do not see you having a problem unless someone complains, from my own experiences even when this happens the greasing of the complainants palms usually stops any escalation
  5. AMG
    This is probably why people are catching more fish inside the piers than on the outside...:rolleyes:
  6. cabobo09
    cabobo09 Member
    Cabo San Lucas
    Inforcement seems to be restricted to Turkey which is random. I guess that's another reason to fly a foreign flag and keep a low profile.
  7. bmar
    bmar New Member
    san diego, ca
    Ha Ha, Sure don't want to try that in the San Diego Bay. Fine are 3000.00 - 5000.00 per Citation. VERY Strict on that.
