Click for Delta Click for Mulder Click for Burger Click for JetForums Click for Burger
Essential spare parts to keep aboard boat?
Discussion in 'Technical Discussion' started by jesid123, Dec 19, 2016.
  1. jesid123
    jesid123 New Member
    We recently acquired a 54 Grand Banks with CAT 3406E engines.
    We keep the boat in South Florida and are planning to cruise the Bahamas extensively this summer.
    Just trying to figure out what essential spares to keep on board?
    Thanks!
    How far and how long are you going to be in the Bahamas for on each trip? How well maintained is everything now?
  3. Zud
    Zud Senior Member
    PA
    Just got my Neptunus with 3406Es'- same situation as jesid123. mine - 1000hrs, brand new aftercoolers, all new filters and fluids. All fluids came back from CAT as clean, resample in 250 hrs. Go
  4. K1W1
    What you need to carry will as stated above depend very much on where and how long you cruise for.
    Filters, belts and Hoses are always handy to have.
  5. CaptPKilbride
    CaptPKilbride Senior Member
    On the water
    I have had good results consulting with mechanics who service the engines as to what they commonly see in the field. In addition to filters, belts, hoses ... I add impellers for the raw water pumps. Maybe a rebuild kit or even a spare raw water pump with the needed plumbing fittings already installed. Other thoughts are spare copper crush washers for fuel fittings... spare fuses...
  6. jesid123
    jesid123 New Member
    The boat will most likely stay in the Bahamas for 2-3 months this summer. The boat was always maintained in excellent condition and there are extra fuel, oil & air filters aboard. The owner cruised mostly US East Coast so parts (and mechanics) were always a phone call away - I'd just like to be a little more prepared for any issues that may occur in the islands.
    If you're spending 2-3 months in the Bahamas this is what I'd recommend.
    Engines
    2 sets of secondary fuel filters
    4 sets of Racors or primary filters, I prefer 10 microns
    set of belts
    set of impellors
    set of zincs
    plenty of coolant and oil
    Gen
    Spare impellor
    spare belts
    spare zinc
    spare raw water pump if it's got some hours on it
    2 spare secondaries
    4 spare racors
    Boat.
    spare zincs
    plenty of cleaning supplies
    spare freshater pump
    Spare bilge pump
    spare float switch
    heatshrink butt connectors
    2 nav light bulbs
    spare interior bulbs
    spare set of lines if you don't have them
    spare grey water pump if you have one
    spare garden hose
  8. motoryachtlover
    motoryachtlover Senior Member
    smithfield, VA
    I would add a spare AC pump to the list
  9. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    Add also a dinghy patch repair kit and a spare prop for the outboard.
  10. Capt J
    Yes, I agree a spare a/c pump is good to have. The dinghy stuff too, if you have a dinghy.
    Ohhhh, and make sure to have a spare macerator pump!!!
  11. Trinimax
    Trinimax Senior Member
    Some spare hoses and clamps for the main engines and generator cooling systems
    also an assortment of spare hoses and clamps for the other miscellaneous systems onboard the vessel ( ac, washdown, fW system etc)
  12. Captain Zemo
    Captain Zemo Senior Member
    Midwest
    Spare hose clamps
    A good hand tool set, to include ohmmeter, wire cutters, electrical tape, selection of connectors with crimping tool, battery-powered soldering iron, and solder. Cordless electric drill with bits.
    First aid kit in water tight container.
  13. motoryachtlover
    smithfield, VA
    I agree on the macerator as the Bahamas don't have many pump outs. Also on my 1995 boat I have been running into a number of hose clamps with cracks in them. So an assortment of hose clamps has gone into my tool box.
  14. Capt J
    Start using AWAB hose clamps, they are much higher quality and you'll most likely never have to change one again.
  15. motoryachtlover
    smithfield, VA
    Thanks capt J. Are the Arabs the more expensive ones that west sells?
  16. Capt J
    No, those are ABA's, they're almost as good as the AWAB's, I prefer the AWABs. http://awabllc.com/
