Click for Furuno Click for Delta Click for Mulder Click for Walker Click for Ocean Alexander
Engine Room Floor Conditioning product?
Discussion in 'General Yachting Discussion' started by tonymaz, Jul 6, 2010.
  1. tonymaz
    tonymaz New Member
    Ft Lauderdale, FL
    I was wondering what you guys use to condition the rubber floor panels in your engine room. I've been using 303 aerospace protectant, it works ok. Any better suggestions?
  2. K1W1
    Using Polished Stainless Steel Diamond Plate negates the need to do very much.
  3. NYCAP123
    Be careful with that. Almost anything you use to pretty up rubber will make it slippery. Best thing is to replace it. Diamond plate like K1W1 suggests is great, but hard on the feet and worse on the knees if in a smaller engine room where you have to get down. It also loses its shine when certain chemicals hit it.
  4. ychtcptn
    ychtcptn Senior Member
    Lighthouse Point, FL
    We've been buffing ours out with a good marine grade cleaner wax, like 3m or Maguires. Comes out nice and shiny, and no problems with it being slippery unless its wet.
  5. NYCAP123
    That's one heck of a caveat on a boat. (or your shoes are)
  6. CaptPKilbride
    CaptPKilbride Senior Member
    On the water
    303 is the best stuff I have found for doing rubber surfaces like this. It has protectants, makes it look good, and doesnt feel greasy to the touch when it is dry like Armor All does.
  7. Minnow
    Minnow New Member
    I have used mop n glo which gives good results on the black raised coin vinyl/rubber type deck coverings, easy application with a product soaked rag and some elbow grease.
