Click for Abeking Click for Walker Click for Nordhavn Click for Delta Click for Westport
Engine Removal
Discussion in 'Luhrs Yacht' started by Chuck Taylor, Feb 18, 2023.
  1. Chuck Taylor
    Chuck Taylor New Member
    Seneca Creek MD
    how do you gain access to the engine of a Luhrs 28 hardtop for total removal.
  2. cleanslate
    cleanslate Senior Member
    Cherry Hill, NJ
    Remove all hatches and any other obstacles in the way, with out cutting things apart. Re- evaluate things after all is removed from above.
    Motor probably will have to come out in sections. I would remove the exhaust systems first. Then see if it can be raised up and out then.
    If not , more has to be removed from the engine till it can come out.
    No two boats are exactly the same in many cases unfortunately.
    Anyway , I always liked your Sneakers!
    I have a classic red pair, high tops of course.
