Click for Walker Click for Delta Click for Northern Lights Click for Ocean Alexander Click for Cross
Engine Controls
Discussion in 'Technical Discussion' started by SplashFl, Sep 27, 2025.
  1. SplashFl
    SplashFl Senior Member
    S. Florida _ Bertram 46
    Boat currently has a Hynautic hydraulic 3 station set up. Finally found a very knowledgeable mechanic who has a source for parts and rebuilt all the stations but although their no longer as stiff as they had been I'm thinking might be time to change to electric. I only know of Glendenning but have seen photos of others. What do you all recommend and why ??
  2. rtrafford
    rtrafford Senior Member
    Vero Beach
    I used Kobelt with good success. I won’t ever leave my Hynautic hydraulics in exchange for electric.
  3. SplashFl
    I had a "taste" of electric after repowering a Contender with a pair of new fly by wire Suzuki's; became spoiled & I suppose was expecting too much by having the hydraulics' rebuilt.
    I have become a little worried about Glendinning lately.
    With mechanical throttles and clutches, The ole ZF controls may need to be looked at.
    I did not think you would be much impressed with your Hynautic controls after service.
    My old original Pannish controls are still finger light and fast.
  5. SplashFl
    I may have been expecting too much from the current hydraulic system so the plan is to check them with fish scale to see if they fall in the 5-7 lb. range and if so just live with it as still concerned about lightning destroying an electric system.
  6. mapism
    mapism Senior Member
    Sardinia
    Amen to that!
  7. mapism
    Sardinia
    It takes much less than a lightning, to develop a fault in anything electronics.
    Regardless of the levers load (which for better or worse will always be higher than electronic, obviously), what you've got is one of the most reliable control systems ever, if properly maintained.
    So, if you're concerned about reliability, something better is still to be invented.
    There's only one reason I can think of for jumping on the electronic controls bandwagon, and it's if you plan to install also a remote control, because I believe that would be tricky to interface to the Hynautic system.
  8. SplashFl
    Based on their web site Kobelt produces both electric & hydraulic. Appears hydraulic systems require "wrist pressure," vs. electric that sends a signal to the E/R where an actuator does the work. Which are you using ??
    Capt. Ralph, despite replacing the cables with the best known at the time on the previous Bert hooking up the 3rd station (Tuna Tower) caused the other 2 stations to not properly work so no controls were attached up there. Probably just as well since the old GF loved the height and last thing I needed was her messing with them while underway. The current Hynautic set up has the E/R actuators hooked directly to engines & gears with 0 cables involved. When I get around to putting the fish scale to them I suspect I'll find normal pressure and if that's the case will need to eat more wheaties. :D
  9. SplashFl
    Your point of view reflects that of the current mechanic who works on both. The other day he was telling me another Hynautic job waiting for him has controls that are completely frozen. Evidently that boat has not moved in 3 years.
  10. mapism
    Sardinia
    That reminds me of something I had in mind when I previously wrote "for better or worse", but I didn't mention explicitly.
    I actually prefer levers requiring a positive effort to be operated, as opposed to those that can be moved by just about anything that gets in touch with them.
    No prize for guessing how I know that a lady moving around the boat with a bag is more than enough to accidently accelerate/engage/disengage/whatever electronic levers - just as an example... o_O
  11. mapism
    Sardinia
    Can't be bothered to look at their website, but R U sure?
    The only Kobelt controls I ever came across are either electronic or pneumatic.
    With the former MUCH more popular than the latter, so I would guess that electronics is what rtrafford was referring to.
    But I can't and don't want to speak on his behalf, obviously!
    BTW, one thing I like of Kobelt electronic levers is that in the event of a system fault, their actuators can still be operated with mechanical levers directly connected to the push/pull cables going to the governor and g/box. So, if I will ever consider replacing my fully mechanical levers (which is very unlikely), Kobelt would definitely have a high place among my preferred alternatives.
  12. SplashFl
    Bad me, I meant pneumatic, not hydraulic but would not want to have to deal with an air pump so it's going to be, stick with what I have or take the plunge to electronic.
  13. Capt Ralph
    I'm a big fan of simple and reliable.
    K.I.S.S.
    Let us help you, spend your money on something more positive and fun. :D
  14. rtrafford
    Vero Beach
    I used the electrical units on a palm beach helm.
  15. rtrafford
    Vero Beach
    Yes, fully electric units. I installed them myself. The Cats-end was the bigger challenge for the learning curve than the Kobelt. Never gave me an issue other than a lightning strike nearby that required an overall replacement. Can't blame Kobelt for that...
  16. Capt J
    You don't want kobalt, they are not the correct controls for your application ( a SF). You only see kobalt on slow motor yachts and not a ton of support for them. ZF controls, sturdy controls or others. ZF is probably a good choice and has good support.
    SplashFl likes this.
  17. rtrafford
    Vero Beach
    My experience was via my choice, my own installation, and via a PB helm on a SF, for a decade with zero issues minus the lightning event. When I had the hit I called Kobelt, and they came out quickly and replaced the parts under an insurance claim. Following, three years later, no issue. She's still operating today, a decade later without issue as I understand.
    Maybe I'm an outlier, but I'd do it again based upon my experience.
    mapism likes this.
  18. Capt J
    Maybe so, but they are not a brand you ever see mounted on the FB and tower of a sportfish. Nor do you see them mounted in a wet environment.
  19. rtrafford
    Vero Beach
    ….but isn’t this more a pattern of proprietary controls? If you walk up to my former console you won’t know Kobelt was aboard unless you looked for the remote function panel. PB side controls could be any manufacturer?
  20. Capt J
    I'm taking boats that were converted. Kobelt are a bit old school looking, but they're not known as being as waterproof as some of the other brands and I've never seen a set of them on a Sportfish or fast motoryacht, ever. Only ever used them on trawler like boats and slow my's. I really liked the Sturdy controls that CAT was using, just in features, durability, and feel. Those were my favorite. The Man rex roth are good as well, and zf's after that. But on a conversion generally ZF are the go to. Keep in mind you need many different parts to make it happen, actuators, harnesses etc etc.
