Click for YF Listing Service Click for Mulder Click for Glendinning Click for Furuno Click for Walker
Electrical System Project....
Discussion in 'Ocean Yacht' started by Dan Thibault, Jun 6, 2016.
  1. Dan Thibault
    Dan Thibault New Member
    Murrells Inlet, Sc 29576
    Hi Everyone....
    Newbie Dan Here...
    Anyone have a copy or access to the electrical layout of the engine starting & paralleling system used on late 80's early 90's
    Three solenoids were used... two for combing two 12v bats to make 24v starting and the third for paralleling port & starboard...
    I believe they had a fuel or oil pressure switch in the start button circuit to prevent the starter from engaging a running engine as the running engine starter button was used in the function of parallel starting???
    Thanks in advance....
    Dan Thibault
  2. Dan Thibault
    Referencing 55 Ocean Yachts
    Not sure totally. A 63' Ocean I used to manage had the solenoids mounted on the foward bulkhead of the engine room. They weren't too expensive, I think around $250 each. I'm not sure on the oil pressure or fuel pressure safety, guess you're going to have to trace the wiring.
