Click for Ocean Alexander Click for Mag Bay Click for Furuno Click for Burger Click for Mulder
Dynamica marine genset
Discussion in 'Generators' started by kev cribb, Jun 19, 2021.
  1. kev cribb
    kev cribb New Member
    Gibraltar
    Hi all
    Can someone please help I am going spare. I have a friend who has a dynamica genset attached to a faryman 18w engine. Whenever it starts it runs for a short period then shuts down. It won’t show volts or amps does anyone have any ideas.
    Also I need to check the wiring inside the control box mounted on the engine casing with breaker Does anyone have a picture or any wiring diagrams for this set. If I have a picture of the inside I could check and trace all the wires going into this.
    I’m back there later so any other required info I can get then.
    Thanks for anyone’s input on this.
  2. chesapeake46
    chesapeake46 Senior Member
    Do you mean the engine shuts down or the engine continues to run and the electric fails ?
  3. kev cribb
    Gibraltar
    No the engine shuts down before any electric power comes to the boat from the engine
  4. Liam
    Liam Senior Member
    Malta
    The symptom usually means a rewinding of the motor attached to the engine, or the electrical panel which controls electrical generation is damaged.
    If you use the generator very little most probably it is the first.
  5. kev cribb
    Gibraltar
    That’s why I am wondering if someone has a wiring diagram to check that side of things first.
