Click for Walker Click for Cross Click for CL Yachts Click for Westport Click for Nordhavn
Duel fuel gauges, windlass remote
Discussion in 'Carver Yacht' started by tommyfmu, Jul 7, 2010.
  1. tommyfmu
    tommyfmu Member
    Freeport, NY
    New Carver 325 owner here. Has anyone added an extra fuel gauge so that the stbd and port tanks each have their own gauge that are always showing 'real time' fuel levels instead of the momentary switch that shows either tank?
    Secondly I just ordered a helm remote for the windlass. Can anyone recommend where to run the wire from the anchor locker up to the helm? The manual says to use 14 awg and the hookup is easy enough.
    Thanks, Tom.
  2. timjet
    timjet Member
    Tampa, FL
    My Carver 355 has the same fuel gauge setup, momentary switch to view levels. It is a bit strange and I would like to change that as well, but is a long way down the todo list. Should be easy enough, install the gauge and readjust the wire from the momentary switch. Just remember to shutoff electrical power to the helm when leaving the boat for extending periods so the gauges don't drain the battery. Very little drainage but drain it will.
    I recently had to change both the sending units, the port was a real pain due to access.
  3. NYCAP123
    I wouldn't bother adding the gauge. They're not all that accurate anyway. Besides, they'll burn pretty close to equal. So, when it starts going down take a second and flip the switch for peace of mind. It'll take you less time to get used to this situation than it will to change the gauges.
    As for the windless wire, you can run it above the headliner in the cabin. Install a second switch at the bow. You'll probably use that one more.
  4. tommyfmu
    tommyfmu Member
    Freeport, NY
    NYCAP, as I'm new to owning a salon cabin, what's the headliner? I poked my head into the anchor locker and the windlass battery cables are run straight down through the V berth forward storage locker in a conduit to the keel but I haven't traced it further than that yet. At the bow there is an up switch and a down switch so tapping into them with 3 conductor 14 AWG won't be hard.
  5. NYCAP123
    The headliner is the soft ceiling which is generally held in place with clips, however, if you have a conduit, does it lead to the engineroom or is the battery in the v-berth? If it runs to the engine room then use that. Run the wires to the engine room and then follow the helm controls up. If not, go above the headliner, then up the post (probably one back from the winshield) that carries the helm controls up from the engine room to the bridge.
  6. tommyfmu
    tommyfmu Member
    Freeport, NY
    The battery is not in the V berth; I'm going to head down there in the next day or so and see where the cables go from the fore storage locker. I'm guessing that they head straight to the engine room. If I get 14 awg from the anchor locker into the engine room, then it will be up to the helm from there. I have to find where the controls are run up from the engine bay to the helm; I'll look where you said, somewhere behind the windshield, stbrd side.
  7. Fireman431
    Fireman431 Senior Member
    East central Florida
    Regarding the fuel tanks, are they connected together? Meaning do they use fuel at the same rate from both tanks or do you have to switch back and forth?
    If they are used equally, wouldn't it make more sense to run them low and plumb an equalizing tube between them? Then 1 single gauge would read both tanks and you would be able to balance the fuel use without trying.
  8. tommyfmu
    tommyfmu Member
    Freeport, NY
    The tanks aren't connected together. The two engines and generator have valves that select where they pull fuel from, stbd or port (or off). Fireman, what you suggest could be done, although plumbing an equalizing tube in including draining and gas freeing the tank, would be way down on a list of things to do. Just had a distributor put into the port eng, and got stuck today with a bad solenoid, although jumped it to get home then replaced it, no big deal.
  9. timjet
    timjet Member
    Tampa, FL
    My Carver 355 diesel saddle tanks are connected together with a transfer pump.
    The genset is fed only from the port saddle tank. The transfer pump lines enter the tanks from the top. I would not consider installing a equalizing line between the saddle tanks because that would require putting a hole in the tank below the fuel line. Not a good idea. It would be just a matter of time before a leak would develop.
    Gas boats of the same size I believe do not have the transfer pump for reasons I don't know.
  10. Seafarer
    Seafarer Senior Member
    Hudson River
    One of the best reasons I can think of is gasoline and electric motors in confined spaces are not the best of friends, indeed they may come to have an explosive relationship.
  11. Fireman431
    You already hve the lines and valves in place, but it sounds like just a replumbing could handle your problem (if equalizing was an option).
    Clamp of the hoses from the saddle tanks, drain the fuel from the hoses, place a 4-way Jandy-type valve:
    2 outputs feeding each engine
    1 output deeding the Genny
    1 off position
    But, obviously, only you know the accessibility of your vessel and whether or not it will accomplish what you want it to do.
