Click for Westport Click for JetForums Click for Abeking Click for Burger Click for Burger
drippless shaft seals
Discussion in 'Props, Shafts & Seals' started by thatcher, Mar 20, 2012.
  1. thatcher
    thatcher Member
    nassau, bahamas
    hello everyone - I have replaced my drippless shaft seal manufactured by tides marine. There is no more leaking, however if you knock it, it will squirt water. Any sugestions on how to stop this.
  2. Marmot
    Stop knocking it.
  3. Beau
    Beau Senior Member
    Beaufort, NC
    Marmot, practical advice as always!
  4. Bill106
    Bill106 Senior Member
    Beaufort NC
    Darn it, now I have to clean my keyboard again Marmot!!!:D
    I suspect your dripless housings needed more than just a lip seal replacement. If they were under a bind (due to missalignment?), and the cutlass bearing inside is worn, it will allow the whole assembly to shift laterally far enough to open a gap on the lip seal and leak.
  5. Capt Ralph
    Make sure the seal AND seal housing are square with the shaft. The shaft log hose should be supporting but yet a little flexible to allow the seal assembly to float. The shaft needs to be pretty centered in this shaft log hose also.
    When You put the cover back on, the seal may be a little difficult to get all in the housing (log cup?) but it has to be all the way in and even. Don't rely completely on the screws to to draw the cover down and call it done. Pull the cover back off and double check with a flash light that the o/d of the seal has not deformed and is in all the way.
    And of course; stop knocking it...
  6. RT46
    RT46 Senior Member
    Marmot,
    thanks for the good laugh
