Click for Burger Click for Abeking Click for Cross Click for Glendinning Click for Walker
door latch
Discussion in 'Technical Discussion' started by leihao, Dec 17, 2009.
  1. leihao
    leihao New Member
    mechanical
    Hi;
    I am trouble in designing a close system of stern watertight door, which is for tender garage. I would like to use the hydraulic--pins and handle latchs together to close the door?
    But I donn't know what type latch is better.
  2. corinthian99
    corinthian99 New Member
    London, UK
    Hello
    Not quite sure what you mean by handle latches - dogs that swing out of the door as in a manually operated door. I think every hydraulically operated door I've seen has been secured by pins. Its mechanically very simple and easy to set up proximity switches to verify the pin's position. One mistake I have seen is where the tip of the pin has no chamfer - if the door is not well aligned the pin jams against the door rather than slipping into its hole usually resulting in a large bang and bits of metal flying off.
    Might want to post a photo of exactly what you mean.:)
  3. Henning
    Henning Senior Member
    Ft Lauderdale FL
    I've seen rotational dogs with central hydraulic actuation as well. Instead (actually in addition to the)of a wheel in the middle of the door, they have an arm hooked to a hydraulically driven linear actuator. You pull the pin which engages the traveler to the worm to use the wheel.
