Click for Northern Lights Click for Delta Click for Ocean Alexander Click for Cross Click for CL Yachts 99X
dock water softners
Discussion in 'General Yachting Discussion' started by ArielM, May 19, 2011.
  1. ArielM
    ArielM Senior Member
    Los Angeles
    Can anyone tell me how much better a water softner mounted on the dock is in regards to water spots after washing your boat? Is it really true that you dont need to dry the boat after? Any good manufactures to recommend?
    This one was in the latest edition of PMY.
    http://www.stainlesswaterfilters.com/order.htm
    They help considerably, however you must backflush them every 500-1000 gallons or they stop producing soft water.
  3. C4ENG
    C4ENG Senior Member
    Ft Lauderdale
    In my experience I have found that trying to soften the water before it goes to the tank does not work very well. The tank is usually already contaminated with trace minerals and by the time it comes out of the vessels faucet, it is hard again (and I tested it with the strips before and after). Best to soften the water right after the vessel's water pump. The deck crew always loved that.
    He's talking about using it for washing the boat via a hose directly from the softener and they work well for that.
    I would never use a softener for filling the water tank. I'd rather have the chlorine and chemicals to keep the tank from growing algae and such.
  5. Capt Bill11
    Capt Bill11 Senior Member
    Sarasota/Ft. Lauderdale FL
    It depends on what water your tanks are made of. Chlorine is not good for aluminum tanks. So it's better to filter it out as the water goes in.
    And some of the larger filters are good for well over 5000 gallons before you have to recharge them.
    http://www.yachtmate.com/watersofteners.html
  6. GrahamF
    GrahamF Senior Member
    Palma Spain/ South Africa
