Click for YF Listing Service Click for Nordhavn Click for Burger Click for Perko Click for Burger
Diagnostic Code 43
Discussion in 'Cabo Yacht' started by Badcofish, Jun 16, 2020.
  1. Badcofish
    Badcofish New Member
    Oakdale
    I have a 2002 35 Cabo flybridge with 3126b cats in it. If the motors are off and ignition is on the orange diagnostic light give me 43 as a code. Code 43 says open or short circuit of injection actuation pressure sensor. Motor starts fine and seems to run fine any help would be appreciated.
    Time to get a CAT mechanic out to your boat. Between this and the gauges, you have a wiring issue on your engine. A good CAT mechanic can probably find and fix it within an hour or two.
  3. Badcofish
    Oakdale
    Ok thanks in the process of trying to get a guy
  4. NYCAP123
    Agree, this is not something you are going to diagnose or fix on your own. It could be as simple as a bad sensor or injector or it could be a bad ECM.
