Click for CL Yachts 99X Click for Abeking Click for Cross Click for Burger Click for CL Yachts
Detroit Diesel 8v92 Oil questions
Discussion in 'Engines' started by Pio Casadey, Nov 4, 2018.
  1. Pio Casadey
    Pio Casadey New Member
    Port Otange florida
    Hello there. I was hopping for some help in clearing up what type of oil to use, delo 100 40w or rotella t1. I changed the oil my self last season using the rotella and now I wanted my mechanic to do it but he said that delo 100 was the only oil that should be used in these engines is that correct?
    Also does anyone now how to stop the small oil leak that is coming from the side oil pan plugs. it as simple as just torqueing them down a bit or something else. Any help would be appreciated.
  2. Pascal
    Delo 100 40W is what most people use but many use Rotella and it s fine As long as it s straight 40
    Do not use Delo 400 40W, they charged the formulation in the early 2000s and it s no longer compatible with Two stroke DDs
  3. Capt Ralph
    Look at the API tag. It has to cover CF2. Not CF3 or 4. CF2.
    Delo100/40 I think covers it. Shell T1/40 Covers it. NAPA Fleet, PN75118 Covers it.
  4. cleanslate
    cleanslate Senior Member
    Cherry Hill, NJ
    As far as your leak goes, yes try snugging it up. But do not over do it, as it may break or strip out. If it's cross threaded you may have a problem and have to re tap the threads, carefully. You could also try some Teflon tape on the plug too.
    What should he do Capt Ralph? see what the pro says....
  5. Capt Ralph
    Don't condemn the plugs yet. A light oil leak down the pan side may just be collecting on the plug threads. Wipe your fingers along the pan sides above the plugs. If it's oil slippery, the leak is from above.
    Usually the pan gasket or air box covers.
    I'm assuming it's a J&T cast oil pan. Usually not a problem. If you really think it's the plugs, Try to snug them, don't lean on them, Just snug.
    If your still convinced it's the plug, wait till next oil change. Put a pan down there and plan on another 1/2 gallon of oil coming out. Pull the plug, reseal with 505 or blue dope and re-install.
  6. Boomer
    Boomer Senior Member
    Seminole
    And there you have it...do what the master says...he has seen it and done it all probably a million times
