Click for Ocean Alexander Click for Mulder Click for Westport Click for Burger Click for Westport
Detroit 8v71's sunk
Discussion in 'Engines' started by graeme mac, Jan 12, 2017.
  1. graeme mac
    graeme mac New Member
    perth australia
    Hi Guys,
    New to this and apparently didn't put my blog in the right place.
    Boat sunk, stbd motor went under, port water came in through dip stick.
    Big fight with insurance company who after nearly a year paid out $20k instead of the $150k I was insured for. Legal advice: take the money and run!
    Cast iron muffler blew hole in the bottom. "Fair wear and tear. Corrosion" etc although I had inspected mufflers as best I could only a few months before.
    HAve been advised by one of the two best Detroit specialists in Western Australia that we may get the motors turning again, so have been pouring down bores a mix of acetone/hydraulic fluid 50/50 as I see that this is the best formulae for rust removal.
    The boat was/is a 1962 55' Chris Craft Constellation which I brought in from Seattle and spent 3 years doing upgrades to her. Nearly finished then that happened!
    After loosing all my belongings and home in a fire three weeks before - under insured - my fault - and as a person who has paid taxes all his life but invested wisely and now gets nothing in return from 'the Nation' am looking for the most inexpensive way to get these motors going again. Then we tackle the electrics!
    Any sound advice would be appreciated.
    And thanks to Captain J for his speedy response - have tried to go back direct to him.
    Cheers
    Gbmacca
    Balmy 35c here today
    Different thread, same answers.
    Sorry for your bad luck.
  3. Pascal
    Yep. Same answer ... the window to pickle sunken diesel is a couple of days. After that rust has started and they re done
    I once save a genset that ingested salt water using diesel in the crankcase circulated with the starter. Drained and replaced a couple of times followed by oil, again drained and replaced a couple times
    But that was within 12 hours of the incident
  4. graeme mac
    perth australia
  5. graeme mac
    perth australia
    Hi Pascal
    Originally had the motors turning over - 48 hours later - shooting diesel out the bores - but had to stop as incorrect socket.
    Was then told not to touch them for insurance purposes which sadly I lost.
    Detroit specialist says - after checking bores with camera and only finding small surface rust - that we may have a chance.
    Said could take 2 -3 months then they may give.
    So, I either get my boat back or end up with a floating caravan!
    Will keep you informed.
    Cheers
    BAlmy 32c here today
    OR, you do get them running eventually and spin a main bearing(s) and then the block is junk and have to pull it from the boat. If they don't free up in days, I'd say they're toast. You may want to fill the entire crankcase full of your mixture and let it sit for a few days too if you're going to attempt this.
  7. graeme mac
    perth australia
    Yeah. Have kept sumps full from day one - so hoping all well at the bottom end.
    Drained all water from both motors and gearboxes then filled with diesel.
    Will give it a couple more weeks then will resort to floating caravan!
    Cheers
    Gbmacca
    Take the air box inspection covers off, it may help when you go to bar them over.
  9. K1W1
    If the engines do not turn, take the heads off and try again. The stuck ones will push the liners up a bit and as the pistons go into the liners from the bottom and then the whole lot is installed as a unit you can just drop the sump and undo the conrod bolts on those ones and remove them in one. The stuck ones will probably be very rusty. I have flown from NZ to Tahiti to a 53 series that ingested water when stopped. Replaced one piston/liner assy and got it going again just fine.
  10. graeme mac
    perth australia
    Hi
    HAve taken them off but not when I pour mix into cylinders, the pistons which are below the flutes, just leaks the mix down the side of the engine.
    Thought I would put them back on - **** job - and pour more down so motor is saturated.
    Thanks again.
    Cheers
    Gbmacca
  11. graeme mac
    perth australia
  12. graeme mac
    perth australia
    Thanks for your reply. Much appreciated.
    Yes, this would be the next step.
    Although concerned that stuck pistons would push liners up and then would not reseat with **** under the lips.
    MAybe we can somehow bolt them down.
    Very, very hard to get under motor to undo bearing caps but maybe younger mech could do it. My knees stuffed so have difficulty with that stuff.
    Am currently recycling the mix in the sump as I can still smell some acetone in it. Will put some fresh acetone into it as I have read this to be a great rust 'free-er'.
    Your thoughts?
    Cheers
    Gbmacca
  13. graeme mac
    perth australia
    One thing I do need to ask - as I have now got a long hollow bar over the socket and bar, is will I snap the main bolt on the pulley if I use too much force.
    HAve read where a guy used a 6' bar and sledgehammer to get his motor free, which was seized for a year, going again!!!
    HAve also just bought a block and tackle as it was suggested that I keep pressure on the pulley and crank it up a notch or so each day ----
    CAn do it on the stbd motor but the port will need some ingenuity!
    Cheers
    gbmacca
  14. K1W1
    If you refit the air box covers also block the drain for the space before adding liquid or your fluid will run out of there. Unfortunately given the time frame since sinking this work might all be in vain. I was not suggesting that you could simply refit the liners with stuck pistons, any with stuck pistons will need to be renewed. If you have the engine that far in bits after a flooding you should put the effort in to look at and check as much as you can. DD's have a lot of cast iron in them , this is a material that loves to rust.
