Click for YF Listing Service Click for CL Yachts Click for Nordhavn Click for Burger Click for Westport
Descaling a manifold system.
Discussion in 'Viking Yacht' started by Val fichera, Jul 10, 2022.
  1. Val fichera
    Val fichera New Member
    Cape may
    Possibly need to descale all sea water systems again. Has anyone set up valves In line ? So u don’t have to keep pulling stuff apart evrytime
    Looking for some info to make this job easier. Just had marina do it a few month ago. But seems to be plugged up again. Ac units showing hi ps
    there is nothing on this biat that pumps above the water line. So everything seem to be more difficult.
  2. f3504x4ps
    f3504x4ps Member
    Cape Canaveral, FL
    Welcome aboard. Question, could you be sucking air? The high temp alarm comes on at dock or while running the boat or both? Can you see the water flow from AC exiting the hull (below water line or above waterline)
  3. Capt Ralph
    I am assuming you are talking about your A C systems.
    If done correctly, chemical cleaning of AC lines should only be required 3 to 5 years.
    You may have just picked up something outside the thru hull. A strainer or hose sucking air.
    Hose could of kinked or maybe some sediment got sucked up and a simple back wash will do.
    Keep it simple first before the chemicals come back out so soon.
  4. Val fichera
    Cape may
  5. d_meister
    d_meister Senior Member
    La Conner, WA.
    +1
    Had an issue on one yacht where everything seemed to be working, but water flow was inadequate. Turned out that the pump impellor had wasted to something looking like more holes than metal.
  6. Pascal
    You may not need to descale again. I have often seen obstructions in a hose, including small dead shells which just pile up at a fitting and inside the manifold. Pull hoses from the manifold and look inside.
    and yes a dMeister mentioned if you have a pu p with a bronze head and impeller they do erode overtime reducing flow
    Capt Ralph likes this.
  7. Capt Ralph
    Please search and read Pascals other post on bronze water pumps. He is most correct in his recommendations on mag/drive, synthetic water pump heads.
