Click for Burger Click for Delta Click for Abeking Click for CL Yachts Click for YF Listing Service
D284xLE4xx Repair Manual
Discussion in 'Engines' started by butch w, Apr 9, 2024.
  1. butch w
    butch w Member
    Arnold MD
    Any one know if the
    CRANKCASE BREATHER OIL SEPARATOR
    is a serviceable item, meaning is there a way to clean them or do you just leave them alone etc. Or if they need to be cleaned/serviced what is the preferred method, thanks
    I have D2848 LE403's. I believe the it is the same part for many of the mechanical engines in the 284....style
    Thanks for any input
    I remember this. Well, bits and pieces.
    Some slow brain cells on this were dissolved a few years ago (lack of use).
    Case vent and the case gases went before the turbo. Just a trap consolidating the oil to drain back into the block.
    Don't remember anything in the manual.
    I recall tearing into a high hour 900CRM. Clean as a bell. Never touched another.
    Our brother mapism Is a great source and hopefully he can chime in.
  3. mapism
    mapism Senior Member
    Sardinia
    I'd go for the latter.
    Unless there's any specific problem you need to solve, but FWIW I never heard of any related to that component.
    Capt Ralph likes this.
  4. ranger58sb
    ranger58sb Senior member
    Chesapeake Bay, USA
    I'm a little hazy on details and don't have the info on board with us just now...
    But I'm pretty sure it was the crankcase breathers that we replaced on our 423s -- to a newer version -- since we were seeing some slight oil burp out the dipsticks, and our MAN guy suggested the older style was the cause.
    Might not be relevant to the 403s.
    -Chris
  5. butch w
    butch w Member
    Arnold MD
    Thank you all for the input, I have had them sitting on the bench for a week and no oil has ran out of them and air flows through them just fine. So I assume all is well with them and they are working as they should.
    I didn't know if they required a cleaning similar in fashion to say a K&N style filter.
