Click for Walker Click for YF Listing Service Click for Westport Click for YF Listing Service Click for Westport
Cummins QSB 5.9 compared to QSC 8.3.
Discussion in 'Engines' started by John Spriggs, May 21, 2021.
  1. John Spriggs
    John Spriggs Guest
    I understand the Cummins QSB 5.9 480hp has an excellent reputation for reliability and long life. 10,000 hours has been mentioned. Can any body say how it compares to the QSC 8.3 600hp, please?
    Both are very good motors. They both run very good. I feel the 8.3 has a lot more torque if going from the 480hp 5.9 to the 600hp 8.3. The 8.3's also tend to run smoother at slower speeds. The difference is size. 5.9 liters and 8.3 liters........ They've been producing both motors many years.
  3. Capt Ralph
    I would consider the 5.9 rather strung out at 480hp. Like the 3208, you can only squeeze so much out of an onion.
    I also think the 8.3 is just getting it's legs moving at 500hp. Todays HO is 600hp. There was a 650hp but emissions forced Cummins to drop that back to 600.
  4. John Spriggs
    John Spriggs Guest
    Thanks guys. Anybody else had any experiences with these engines, please?
  5. GPO
    GPO Member
    Ladysmith, British Columbia
    I’m running QSC 8.3 HO 550’s on my Riviera 41 open fly bridge. LOA 46 beam 15. Advertised dry weight with standard engines 30,100 lbs. Make my weight with my engines, full fuel (2535 litres) and water (460 litres),water maker, larger house bank, zodiac tender, plus, plus, plus, conservatively closer to 40,000 lbs. 80% load at 2600 RPM, 21 KTS (vs advertised cruise 25 KTS with standard engines Cat C7 Acerts 460hp). No issues strictly following Cummins maintenance guidelines. No experience with QSB 5.9 480. Hope this helps.
  6. gr8trn
    gr8trn Senior Member
    OR/WA/CA/BC
    QSB 5.9 380 hp variety for my boat. 40,000 dry.
    some would say underpowered application but I am happy with the application. Maybe related to hull design and Zeus pods.
    Starts, no smoke, smooth, temperature and oil pressure always spot on, coolant top off, Cummins recommended maintenance or more often.
    No complaints.
  7. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    Go large. We,ve had both and there's no saving on either.Man up and feel the burn.
  8. Capt Ralph
    Displacement always wins the endurance game.
  9. John Spriggs
    John Spriggs Guest
    Thank you, everybody. All that answers my question very nicely.
  10. 993RSR
    993RSR Senior Member
    Annapolis/ Palm Harbor
    I am involved with a 2006 boat with twin 5.9's. Due to all the down time and poor maintenance the crankcase pressure is high and smoking on one side.
    I was told by the engine surveyor these motors are not not sleeved. True?
  11. ranger58sb
    ranger58sb Senior member
    Chesapeake Bay, USA
    True.
    The 8.3s are sleeved.
    -Chris
  12. Fishtigua
    Guernsey/Antigua
    Sent 2 of our 5.9's back to the factory for a full rebuild. Worst $60k ever spent. Terrible job, sent them back.
  13. 993RSR
    Sure is nice being able to replace a piston and sleeve with the motor in the boat. Maybe the Cummins do not require that repair as often as Cats.
    Removing and reinstalling the motor can be 5x more expensive than the repair
  14. Capt J
    3208 cats weren't sleeved either and neither are yanmars as far as I know. Removing a 5.9 shouldn't be terribly difficult. Some boats labor might be less removing 5.9's because there's even less room to rebuild them in place. Cummins does have remans at a fair price with warranty.
