Click for Glendinning Click for Burger Click for Northern Lights Click for Cross Click for Abeking
Cummins C series heat exchangers
Discussion in 'Engines' started by enproep, Jun 27, 2017.
  1. enproep
    enproep New Member
    newport beach, ca
    Hello, I have twin Cummins C series diesel's in my motor yacht that are approx. 17 years old with only 950 hours on them. They run great, but I've recently noticed seawater dripping at the end cap of the port heat exchanger (1 drop every 5 to 10 seconds). My mechanic is recommending I replace both heat exchangers at a cost of $7400 for both including labor and coolant. My question is, does this seam reasonable? It does look like the ends of the heat exchanger tubes have been JB welded once before. Can the leak be patched again? What are the ramifications of letting it go for awhile. Heat exchangers, aftercoolers and transmissions were serviced 5 years ago (approx. 300 hrs ago). Thank you in advance for help/advice. Bob
  2. ESSRTEE8
    ESSRTEE8 Member
    56 POST in Monmouth Beach NJ
    Do you trust your mechanic?
    Downside if they are bad is that you will destroy the motor when they do leak.
    Have them pulled, inspected and go from there.
  3. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    Pretty much what Ess says, get them pulled and inspected.
    I just wrote on the Volvo 330 thread about the same thing, almost (I'm a Cummins dealer/ex-Volvo dealer).
    Get them looked at by an experienced engineer and get an unbiased appraisal for repair or change.
  4. enproep
    enproep New Member
    newport beach, ca
    Thank you ESSRTEE8. So, it's probably not recommended to run them until I swap them out? Thinking of doing it myself as I found OEM exchangers for $1600 ea. and they look pretty easy to swap out.
  5. enproep
    enproep New Member
    newport beach, ca
    Thanks Fishtigua. Know any Cummins dealers in So Cal?
  6. Fishtigua
    Guernsey/Antigua
    Ha ha. I'm in the UK, bloody long shot! :D
  7. PacBlue
    PacBlue Senior Member
    Dana Point, Ca
    You have a host of reputable boatyards in your NB to contact and at the minimum, get a recommendation for Cummins service. Basin Marine and Newport Harbor just to name a few.
    There is Seaboard Marine in Oxnard that has published a lot of information on Cummins issues: https://www.sbmar.com/category/articles/marine-aftercoolers/
  8. enproep
    enproep New Member
    newport beach, ca
    Thanks PacBlue, will contact Seaboard.
  9. Fishtigua
    Guernsey/Antigua
    I have to say Seaboard are a mine of information and know B & C Cummins like a boss.
    Recommended!
  10. rcoff512
    rcoff512 Member
    Long Island NY summer Pompano Beach FL winter
  11. Norm Skipper
    Norm Skipper New Member
    Jacksonville, fl
    If you have not solved the problem. The Cummins C Series heat exchangers have removal plates at each end and can be resealed with new gaskets and seals ( the seal is for the center bolt ). Check the plates for cracks ... change the zinc while you are there. If there is not enough room to remove the plates you may need to remove the heat exchanger. You should not need to replace the heat exchanger.
