Click for Glendinning Click for Burger Click for Ocean Alexander Click for CL Yachts 99X Click for Delta
Cummins 6.3 with water in engine oil
Discussion in 'Engines' started by Capt Fred, Aug 3, 2020.
  1. Capt Fred
    Capt Fred Senior Member
    Long Beach CA
    Asking for a boat neighbor, She has a Sealine 42 with Cummins 6.7. Last week on her trip to Catalina, she noted her port engine over heating. She shut down the engine and proceeded to Catalina. She returned from Catalina on one engine and found out that the raw water pump had failed. She had it replaced with a new unit. That mechanic identified water in her engine oil, said it came in from the heads and the engine needed to be rebuilt. Another mechanic said the water most likely came in thru the intercooler. My question is does water in the engine oil (salt or fresh) mean a rebuild. What would be the harm of draining, flushing several times, fixing the water entry point and running without a rebuild?
    She could try, but her odds aren't good, especially with salt. The harm could be a cracked block and a replace instead of a rebuild.
  3. Pascal
    Salt is worst obviously. Depends on how much there is and long it s been sitting. They need to replace the oil right away and crank it without starting to circulate the fresh oil
    years ago, i got salt water inside my generator due to a poor installation (no vented loop). Water syphoned in, filled the muffler and backed up in the engine. I noticed right away and was able to immediately drain, filled with diesel, circulate, repeat a couple of times and then again a couple of time with oil. Saved the motor
    in this case the question is to know if it’s coolant or salt. Coolant would be a head gasket or possibly a cracked head. Salt would be intercooler.
    first thing after changing the oil would be to pull the intercooler and pressure test it. I would do that before pulling the head.
    I don’t see how a cracked block would result in salt water in the oil. Coolant yes but not raw water.
  4. NYCAP123
    After salt dries on the cylinder walls and pistons what happens next?
  5. Pascal
    That s why flushing with diesel and oil has to be done right away. Usually within 24 hours before corrosion starts. Cranking without starting with diesel helps flush the salt. After 24 hours it’s too late
  6. NYCAP123
    If you read the OP it's well past 24 hours already.
  7. Capt Fred
    Long Beach CA
    Yes well past 24 hours, thanks for your replies.
  8. NYCAP123
    Still remember as a kid when a friend dumped his OB into the bay. Out of the water and into a barrel of oil immediately. No problem. Any time a motor ingests or is submerged in salt water pickling it in oil (or diesel) immediately is a must. Don't suppose that mechanic flooded the motor with oil did he? (would have been good)
  9. Capt J
    Most likely a head gasket from the overheating.......did she say exactly how hot it got? You'd have to further diagnose it to see.....could pull the injectors and do a compression test.
  10. Capt Fred
    Long Beach CA
    She is going to try to save the engine. She understand the slim chance of success but what does have to lose. She got a mechanic and got the old oil and filter out and replaced with fresh oil and got the flushing started by running the engine. Will post updates as I get them.
  11. d_meister
    d_meister Senior Member
    La Conner, WA.
  12. rtrafford
    rtrafford Senior Member
    Vero Beach
    Yep, pull the injectors and dump marvelous into each cylinder.
  13. Capt Fred
    Long Beach CA
    It actually starts quickly, sound great and no sheen on the water or increased smoke. So promising.
  14. Capt J
    If the raw water pump is gear driven, perhaps that's how the water got in there......if it ate the shaft bearings......she might get lucky.
  15. Capt Fred
    Long Beach CA
    Capt J, the pumps are gear driven and I thought the same. She had both gear driven raw water pumps replaced. I was telling her to save the old pumps and get them rebuilt but her mechanic told her one pump was too far gone to rebuild?
  16. Capt J
    Generally they should leak out the weep holes when they fail and not in the crankcase, but if it severely ate the bearings, it's possible it could fill the crankcase (in a 1 in a 1000 chance). How hot the motor got before shutting it down and the load it had at the time will be the deciding factor.
  17. Capt Fred
    Long Beach CA
    Update: her mechanic found the leak to be at the intercooler seal. That was fixed and flushed again. Now it is a wait and see.
