Click for YF Listing Service Click for Westport Click for Perko Click for Walker Click for Glendinning
Cummins 480 CE Oil pressure
Discussion in 'Engines' started by Petepd, Aug 10, 2009.
  1. Petepd
    Petepd New Member
    Naples, FL
    The other day my Sea Ray 390 Motoryacht would barely get on plane due to a uncleaned bottom, and I was running it at about 2300 RPM hoping to knock some of the slime off the bottom. When I de-accelerated to idle speed the engine alarms went off indicating low oil pressure , which was about 20 pounds at idle. After a minute it came up to about 25 pounds and when running at 2100 RPM it was about 60 pounds. anybody know why it would drop off like that and what I should do to correct it? The oil is not up to the line but is not below the hash marks.
    Thanks, Pete
  2. CaptTom
    CaptTom Senior Member
    Palm Beach to Ft Lauderdale
    When was the last time you changed the oil/filters? Ever have an oil analysis done? Pump going bad? Did the engine overheat?
    BTW, hard to knock off the growth from the bottom by going fast. Better chance of removing it by cruising over a sand bar. lol
  3. K1W1
    If the Oil Pumos have their pickups in the back I would go along with the Oil being bit low and it all sloshing forwards when you slowed suddenly.
    How much of an angle are you engines on?
    You might find that the full mark on the stick is not the actual full mark.
    CAT have a procedure called Calibrating the dipstick where you fill the engine with the correct amount of oil by measuring the liquid quantity as you pour it in and them you mark the stick accordingly. Not sure if other manufacturers do this but it seems like a good idea.
    There is a YF Member here who is a Cummins guy from California called Sbmar who should be able to answer your questions with some level of certainty.
  4. CaptTom
    As per K1W1's explainations, that's why you never change a dipstick from one engine to another engine without recalibrating. Good thing to check on new engines, too.
  5. Petepd
    Petepd New Member
    Naples, FL
    The oil was changed about 14 months ago, but I've only put about 80 hours on the boat since then. The engines were not running hot. As to the other questions, I have not had an analysis done on the oil, aand I don't know about the pumps. And I'll keep the sand bar idea on the back burner just in case! ;) Thanks!
  6. K1W1
    Instead of sanding it off you could try it yourself with a brush and dive gear or call a diver to do it for you.
  7. Marmot
    Did you decelerate rapidly? It sounds like low(ish) oil level and rapid deceleration simply moved the oil forward and the pump lost suction for a moment, just like K1W1 suggested.
