Click for Burger Click for Abeking Click for Mulder Click for Westport Click for Delta
Cummins 1997 8.3 cta 420 hp
Discussion in 'Engines' started by NOSINK, Oct 18, 2023.
  1. NOSINK
    NOSINK New Member
    FLORIDA
    Can some one tell me where the idle is supposed to be set ? Smooth when in sync. Sync off one motor too low. Thanks Carver 500
    Mechanical or electronic (CR)?
    A model number would be most helpful.
  3. NOSINK
    NOSINK New Member
    FLORIDA
    Mechanical Old school Idle screw. Thanks. Ralph.
    600 is your minimum no load idle.
    With a few hours on the engines, I expect your governor to be a lil loose and late.
    Any issues shifting in/out of gear (dock side maneuvers), 650 RPM may be preferred.
    Trusting the helm tachs is another issue.
    Always verify RPM with a hand tack on the flywheel or balancer.
    Where are you hiding (or near) in Florida?
