Click for Glendinning Click for Walker Click for Northern Lights Click for Perko Click for Cross
Crank Vent Replacement Filters
Discussion in 'Technical Discussion' started by Timothy Tyler, Aug 17, 2018.
  1. Timothy Tyler
    Timothy Tyler New Member
    Noank, CT
    I just purchased an '87 Viking 44 with 671-TI engines. In the process of moving a "Crank Vent" canister, the canister latches came undone and the filter inside just disintegrated. What my research has found is that the Crank Vent filtration system was made by Diesel Research Inc. It appears they may have gone out of business.
    I'm scheduled to bring the boat home to Connecticut from Ontario in a week and need to find a work around for the filter problem so I can make the trip. The best solution for me would be replacement filters, but I can't find any information on where to buy them.
    If they are no longer available, what are my other options to get the boat home? This can't be an uncommon problem, it looks like they were used on a lot of boats back then, but as I said I can't find a source for replacement filters or a solution for what is used to replace the Crank Vent unit itself.
    Any help with this would be greatly appreciated.
  2. MBevins
    MBevins Senior Member
    Windsor On. Canada
  3. Timothy Tyler
    Noank, CT
    Thanks for the reply, but I don't see how to make these work. The largest filter appears to be a 4" Diameter x 1/64" thick disc. The filter I'm trying to replace is about 8" diameter x 8" thick column of foam.
    Any other ideas?
  4. MBevins
    Windsor On. Canada
    I don't think you're talking about the crankcase vents sounds like the air intake at the turbo.
    I'll look for a picture of the crankcase vent.
  5. Timothy Tyler
    Noank, CT
    If you search these forums for "Crank Vent" you'll some threads come up titled "Detroit 671." If you click on the first one and scroll down you'll see some pictures. The last picture is of the unit I'm talking about.
  6. Timothy Tyler
    Noank, CT
    Upon doing some further research I found something characterized as a reticulated, open-pore, flexible, ether-type polyurethane foam. Part of the description is:
    • Filter Applications: Small engines, air compressors, hair dryers, face masks, vacuum cleaners, air conditioning, school and motel ventilators, oil-mist eliminators, automotive air cleaners, industrial panels, electric equipment, projector equipment and dust bag collectors.
    It's sold in sheets so my plan is to cut a strip 8" wide and roll it into an 8" cylinder that fits snugly into the Crank Vent canister. Typical life is listed as 5-10 years which works for me.
    Does anyone see a problem with this plan?
  7. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    Parker-Racor do a CCV6000 that fits the 71.
