Click for Delta Click for YF Listing Service Click for Glendinning Click for Cross Click for Walker
cooling system 1960 430 Ford mel
Discussion in 'Chris Craft Roamer Yacht' started by recon, Aug 30, 2011.
  1. recon
    recon New Member
    Knife river MN
    I do not have cooling on one side of my 430 exhaust.
    The engine runs cool but burnt up an exhaust hose.
    Does anyone have any idea for the possible cause?
    Dean
  2. K1W1
    It sounds like you have a blockage in your cooling pipes somewhere.
    If you were in Saltwater I would suggest some salt left by hi temp ops but assume you are in FW.
    It sounds like you're exhaust manifold and riser is plugged. If they are older than 5 years, I'd recommend changing them. I've also seen thermostat housings on gas motors that have tees on them and they can get plugged also.........and contrict water going to one of the exhaust manifolds.
  4. recon
    recon New Member
    Knife river MN
    I have pulled off the elbow that the water is injected
    into the exhaust and that is clear.
    I am thinking water pump. It looks like they have a
    pump for each manifold, at least I think that is what I
    am looking at, strange looking beasts but the water lines
    attach to it
    Dean
