my ‘88 Ocean 55SS has a freezer on the cockpit next to the engine room. Originally for fish, but now for beer, and what a job it does! I can hold well over 100 cans and they are ice cold. The first issue is insulation, I get a lot of moisture and need to thaw it out and clean it a few times a year. Not a dealbreaker, but annoying. The real issue is power draw and noise. It’s got coils running around the box and a compressor below. It runs off the inverter when off the dock, but it’s noisy when I’d like quiet. I figured this was just the way it was but an ac guy was over last week working on a air con issue and told me these are loud and power hungry and I could put a large cold plate covering 3 sides of the box and it would work just as well but quiet and less energy. Any idea or advice?
A few comments, agree that it is a power hog, and that there is no frost free mode but you may want to reduce the temp to prevent freezing and the condensation should drain to the bilge. I have a Cruiseair unit in my boat and it is not noisy, I can barely hear it running when engines and genset are off. Perhaps the fan is rubbing against something. If you do decide to upgrade, please let me have first dibs on your old compressor unit.
The chiller plates are nice, but the setup is expensive. I was quoted around $7k to do my boxes. I can live with the AC noise...
Plus the stuff against the plates freezes and the stuff in the middle is half cold when you stuff them with your 100 bottles of beer. Insulate the lid with a nice thick but very soft gasket and should help with condensation.
Thats what I was afraid of. I tried a gasket already and it made the condensation much worse. I think better insulation on top might help, and then the gasket may work. I can't argue the performance of the existing unit. Beer is just perfect! Barely liquid, very refreshing on a hot day ')
Can you explain where the condensation is again in or outside the box? Exposed coils around the in or out side of the box? Has the rubber compressor mounts faded away? Tried a gasket and condensation worse?
Condensation is inside the box, there are no exposed coils. They are wrapped around the box interior. Could the issue be poor insulation on the top of the box?
