CMN 60-meter "Diaporama" This 60M mega yacht will follow in the wake of the Netanya 8 and the new Slipstream. She will be of similar construction to the previously mentioned yachts. When completed, she will make her splash into the yachting world in 2009. This mega yacht is called the Diaporama also known as Project 802. Diaporama is set to have a high customizable interior with cosmetic styling that differs her from the Slipstream and the Netanya 8. She will have an overall length of 60M and a beam of 11.20M. A relative draft of 3.45M will ensure her entry into most marinas around the world. She has been designed by Andrew Winch Studios. The hull is set to be made from steel and the superstructure of aluminum. Inside the steel hull the CAT 3516B C rated engines will provide the power to push her through the water. As a result, a top speed of just over 15 knots will be attainable. At slower speeds, the Diaporama is set to have a range of over 5,000 NM. She will be built to the classification standards of Bureau Veritas. Here are some statistics on the Diaporama: LOA: 60M or 197 feet BOA: 11.20M or 36.75 feet Max Draft: 3.45M or 11.3 feet F/L displacement: 903 T Gross tonnage: 1093 GT Propulsion power: 2 x 1641 kW at 1600 rpm Type of engines: CAT 3516B Rating C Generators: 3 x 164 Kw Emergency Generators: 1 x 48 Kw Hull: Steel Superstructure: Aluminum Guests: 12 Crew: 14 Maximum speed: 15.2 knots Range at 11.5 knots: 5 000 NM Classification: Bureau Veritas For more information, visit the CMN website at: http://www.cmnyacht.com/cmn-yacht-project-802.html http://www.cmnyacht.com
