Click for Burger Click for Delta Click for YF Listing Service Click for Westport Click for Walker
Clothes and fabric having fume smell
Discussion in 'General Yachting Discussion' started by catch yaself, Mar 8, 2014.
  1. catch yaself
    catch yaself New Member
    nassau
    I have a 2002 48 ocean SS just purchased a few months ago and I am noticing that our clothes and sheets have a significant smell of fumes
    It's not a noticeable smell in the salon or cabins as your living on the boat but the clothes are quite strong if you smell them when you leave the boat for a few days and go back on
    Has anyone experienced this and any solutions to this problem?
    Yeah many boats. What kind of Fume smell? Is it raw diesel? Is it exhaust smell? Is it bilgey? Sewage?
  3. catch yaself
    nassau
    Its more exhaust smell on the clothes and sheets. When you board the boat and enter salon area it smells fresh and clean but the smell on the fabric is very noticeable. I have blowers on when running the boat but the smell seems to seep into the living areas.
    Again you would never notice the smell just entering the boat.
    The bilge areas are very clean and I clean them regularly . If I open any hatch throughout the bat I dont get a diesel smell at all.
    thanks
  4. Beau
    Beau Senior Member
    Beaufort, NC
    Check carefully for an exhaust leak at the engines and generator
  5. catch yaself
    nassau
    Primarily the exhaust hoses ? Is that what your referring to?
  6. Beau
    Beau Senior Member
    Beaufort, NC
    Yes, but thoroughly check the whole system from the manifolds to the exhaust outlet. An exhaust leak can be fatal as you know.
  7. catch yaself
    nassau
    Will do
  8. AlfredZ
    AlfredZ Senior Member
    Landlocked in Europe
    Do check the whole system and if you don't have CO detectors, it would be a good addition to all confined spaces; If you have a leak, what you smell is your least worry!
    Some boats, are not well ventilated in the living areas and might have only an aft opening with no other opening to any of the sides or so. If your boat is not well ventilated and you tend run the engine(s)/generator(s) while stationary, like when docked, or have a neighbor that does so, fumes will enter your vessel from the exhaust by external air drafts, this is why they would settle on fabrics because it is not intense enough to pollute the whole air in the area (A sign that the exhaust system and engines are running clean with undetectable black smoke or heavy soot!) . Just a thought!
    You can always change the kind of cigarettes you smoke! ;) :p
    Cheers,
  9. catch yaself
    nassau
    We do rub fever stir for 48-72 regularly when anchored off
    We also have detectors.
    Please clarify what you mens when you say engines may be running clean.
    And exhaust is undetectable?
  10. AlfredZ
    Just like in your car, if your engine is running clean, good filters, sparks, timing, etc. and you are standing behind your car while it is running, it takes long time for you to be irritated by the exhaust. Unlike if you had black smoke, you'll be coughing like a spanked chicken in less than a minute. I meant it as a good sign of a clean running engine not more.
  11. Capt Ralph
    Is CO from a diesel engine tall enough to measure? I know a gas engine exhaust will kill you quickly.
    Finally found an exhaust leak on a customers 6-71; the head/exhaust manifold gasket failed under the manifold & out of sight. The owner did have a similar odor problem. We had dry bilges so I figured to look over the system before the dump cans real well. Took a couple of looks still then but found it.
