Click for YF Listing Service Click for Westport Click for Cross Click for Westport Click for Mulder
Cleaning Man CR900 heat exchangers
Discussion in 'Engines' started by CSkipR, Aug 9, 2012.
  1. CSkipR
    CSkipR Member
    New Smyrna Beach, Fl
    I am due to have my heat exchangers cleaned 800 hrs (several years). My local Man mechanic quoted me 8k to have them flushed with barnacle buster which seems high for a flushing job. This doesn't include the intercooler which also needs to be done according to maintenance schedule. Seems I could remove them myself and have them cleaned for alot less. Is it difficult to remove, clean (radiator shop) and replace them?
  2. ArielM
    ArielM Senior Member
    Los Angeles
    $8k just to clean the heat exchanger seems very high. I usually clean them myself but i would think they should be no more then $800-1000 to have them cleaned professionally.
    It is a little complicated to remove, clean and replace them and more labor intensive than most motors because you have to take several things off to remove and reinstall them. I would NEVER and I mean NEVER go through the trouble of cleaning them with barnacle buster for $8k. I would have them electrostatically cleaned at a shop and pressure tested. Do have your aftercoolers cleaned at the same time. However, I've seen MANY MAN owners go much longer before cleaning the heat exchangers if the engines are running at correct temperatures due to the expense.
  4. Beau
    Beau Senior Member
    Beaufort, NC
    Agreed. Unless your are still under warranty. then you have to follow Man's schedule. I have the older 820's. When I had my 1000 hour done, my quys in Mystic said they we "CLEAN". so if your temps are good don't do that expensive work with a wash.
  5. CaptPKilbride
    CaptPKilbride Senior Member
    On the water
    On a positive note, if you have the extended warranty you should be covered on the repair to your heat exchanger they will have to do when they go to take it apart. Let the pro's do it this time because the CR engines have an issue with the header tank that needs to be updated.
  6. Marmot
    How's that work?
  7. Silver Lining
    Silver Lining Member
    Chesapeake/Florida
    An alternative many use is to circulate Barancle Buster or Rydlyme through your heat exchangers without removing them. A recirculation setup that circulates solution directly through the aftercooler, heat exchanger and trans cooler is an effective way to descale and clean the seawater side. Of course the aftercooler needs to be removed and inspected periodically. I also use my setup to clean the genset and AC seawater lines.
  8. Marmot
    That's what you get for $8K.
  9. Silver Lining
    Chesapeake/Florida
    Although I have not used him, Overtemp Marine does "dockside heat exchanger cleaning". I have spoken with the guy a few times and he seems to know what he is doing. His pricing is $1K to do 2 900 MANs and he will do the genset with the left over cleaning solution.
    For $8K I assumed the mechanic was removing the exchangers. It is hard to believe someone would charge $8K to circulate solution dockside, aftercoolers not included! But then I have CATs and not MANs.
  10. Marmot
    It is amazing what lurks at the other end of a cell phone call.
    But you are right, 8K is amazing. Heck, I would do it all day long for $7500.
  11. Capt Ralph
    Those MAN 900CRM H/Es need the end caps pulled at least and new O rings installed. You will be amazed of what trash you will find under that STB end cap. Inspection of the case at the HE ends is also important. If you pull the whole tube from the HE inlet from the air cooler, you can look into the air cooler and see what shape it's in.
    Remember, there are no zincs in this system. Pulling those end caps is a maintenance item it self.
    There is an exchange some of the guys do. It's a reworked case with a fresh core. Ask again your tech of his quote, It may include this plan.
    BTW, the cooler for the computer is also sea water cooled. Flip it up and look for leaks at the hoses. It's under/between the factory 2ed fuel filters behind the air cooler. and flips up and back.
  12. Capt J
    Effective????? hardly.
    8 times out of 10 on heat exchangers I've seen pulled, it's broken off zincs and debris that are restricting waterflow and not scaling. Barnacle Buster and Rydlime do nothing to remove zincs and broken off impellor blades, etc etc.......
  13. Silver Lining
    Chesapeake/Florida
    While YMMV, I have found that changing impellers on an annual basis or as required by maintenance schedules prevents impeller failures. Also using and maintaining appropriate intake screens reduces debris significantly. There have been several threads over the years on the repected boatdiesel web site about the use of descaling agents and circulation systems. I have also read some nice studies by the US Navy evaluating descaling agents and their optimum concentrations for circulation during seawater system maintenance.
    It is not to say that heat exchangers should never be removed or cleaned, but an annual or biannual descaling is an effective way to reduce scale and maintain optimum running temperaures. I monitor WOT RPMs and look for any sign of temp creep, especially in diesels that are marginally cooled or producing very high HP/liter.
    Also, hydrochloric and phosphoric acid, the primary ingredients in Rydlyme and Barnacle Buster respectively, are well known to dissolve zinc which is why you must remove all zincs when performing a system flush. I think small broken off pieces of zinc are likely to be dissolved or significantly reduced in size.
  14. Capt J
    Not really, I've seen heat exchangers taken off after rydlime or barnacle buster is used and still hasn't cured the overheating problem. It seems to do a pretty good job on the scaling, however the zincs and impellor blades tend to be intact and were the problem to begin with. Especially the tube style heat exchangers, the zincs get trapped in the tube and it would take a very long time for rydlime or barnacle buster to try to disolve it. Honestly, on a lot of motors, the heat exchangers come off fairly easy and not much longer than everything you have to do to remove zincs, hook ends on whatever it is to circulate the stuff, etc etc.....plus it's always good to pressure test various coolers.
  15. CSkipR
    CSkipR Member
    Thanks guys the 8k quote was just to flush the HE not remove & clean them. I am getting a quote from another Man service co. to remove & clean HE, intercooler, replace & paint removed parts, etc. Will see how that comes in.
    I did have the extended warranty but it expired earlier this year. The engines are 2005 although not commissioned until 2006.
  16. Capt Ralph
    By chance have you talked to Brian yet?
  17. CSkipR
    CSkipR Member
    Yes Brian is who quoted me the 8k.
  18. C team
    C team Senior Member
    Kent Island
    I am not sure about big diesels, but what I do every few years on my Crusader heat exchangers is mix a solution of muriatic acid. In my case, two gallons of water for every gallon of acid. I remove the raw water intake hose and put it into the bucket with the three gallon solution and let the engine suck in the solution. I shut down the engine and let sit for 30 minutes of so. Re-attached the raw water intake hose to the thru-hull and fire up the engine and flush out the acid solution. Keeps my coolers and risers clean. You will have to replace any zincs that are in the coolers if you did not remove them before the cleaning.
  19. Capt J
    In addition to the heat exchangers, the valve adjustment and head bolt re-torqueing is very important as is checking the injectors at the 1000 hour mark.......on MAN's.
