Click for Furuno Click for Westport Click for Abeking Click for Mulder Click for YF Listing Service
Classic (Fairbanks Morse or old Deutz) vs New Diesel Mains
Discussion in 'Technical Discussion' started by TeKeela, Dec 18, 2014.
  1. TeKeela
    TeKeela Member
    NC & Puerto Rico
    Hypothetical...
    Take a Fairbanks Morse in the 650hp range made in the 60's vs an equivalent say Caterpillar. I assume those engines were slow turning and continuous duty. So compare an equivalent Cat, maybe a C-18 continuous.
    1. would the newer engine be more fuel efficient?
    2. would you be able to find parts for the older?
    3. would you need a heavy parts schedule for the older as it is slow turning, thing has worked for 50years.
    4. significant size difference between the two, assuming a C-18 to compare.
    5. if it was in a boat and working, would you want to swap it for reliability?
    Out with the old and in with the new, or keep the classic, it's experienced and trouble free?
  2. bernd1972
    bernd1972 Senior Member
    Flensburg, Germany
    If replacing such an old beast I´d rather take the 13,5Liter Deere than a CAT...
  3. TeKeela
    TeKeela Member
    NC & Puerto Rico
    ok, why? serviceability? cost to operate? fuel consumption?
  4. TeKeela
    TeKeela Member
    NC & Puerto Rico
    And the old engine would be a slow turning in the 750rpm range so I'm assuming it was naturally aspirated?
  5. bernd1972
    Flensburg, Germany
    The Deeres are probably among the most durable and reliable engines on the market and even some serious bit cheaper than compareable CATs.
  6. TeKeela
    TeKeela Member
    NC & Puerto Rico
    I know Deeres are very popular in commercial applications. However the model referenced above is turbo charged high speed. At the point the turbos kick in, the fuel consumption increases dramatically. I'm trying to get into my head, if space is not an issue, would a bigger older non-turbo slow turning engine be better fuelwise than a newer turbo high speed replacement? Aside from a smaller package for the same horsepower, what do you gain with a modern high speed diesel compared to a slow speed classic?
    Well that totally depends on the boat and it's operation. If you can give us that, boat/size/cruising speed/hull type......it would help a lot.
  8. TeKeela
    TeKeela Member
    NC & Puerto Rico
    It is a commercial boat 50m x 10m x 3m with a pair of fairbanks that seem to be 750hp and about the same rpm. The specs were 34gph at 9-10kts cruise including one generator. I was just thinking about old vs new and that seems to me awfully good fuel consumption for moving something of that size. But since the engines are so old, could consumption be further reduced with modern technology.
    I love the idea of conversions over a new build. Not in my future at the moment but I do like to crunch the numbers.
  9. Capt J
    I think you're probably not going to get better fuel economy with new diesels, most likely worse. I would think you're going to need de-rated 12 cylinder CATs like the 3508 series just to have the torque to move a boat that size. I don't think C18's would be a good fit. Parts will be easier to come by and reliability may be better. I don't know.
  10. K1W1
    Here we go again, How can a 3508 be a 12 cylinder engine?
  11. leeky
    leeky Senior Member
    Florida
    Be careful there, K1W1. Capt J might accuse you of SPLITTING HAIRS.:p
  12. Capt J
    Woops........it's a very large displacement 8 cylinder....... However the C18, isn't that large of displacement 6 cylinder.
    Aside from calling me out on my clerical mistake. Kiwi, what is your recommendation for this man and his yacht?
  13. Capt J
  14. TeKeela
    TeKeela Member
    NC & Puerto Rico
    To clarify, it is not my yacht, but I do wonder about converting a commercial boat. I'd like to do that one day and I enjoy figuring out the old vs the new, what would stay and what would go. Fuel consumption is no more than a 60' convertible and you can bring a lot more toys and tow the convertible.
  15. TeKeela
    TeKeela Member
    NC & Puerto Rico
    There is no replacement for displacement.
