Click for Westport Click for CL Yachts 99X Click for YF Listing Service Click for Delta Click for Abeking
Class B AIS installation
Discussion in 'Technical Discussion' started by Maxwell, Jan 11, 2016.
  1. Maxwell
    Maxwell Senior Member
    Door County, WI
    I am in the process of upgrading all of the electronics on the boat and as part of this, installing AIS. I can either install a dedicated AIS antenna or split the current Shakespeare VHF antenna and use it for both. If I split the current antenna, will there be a noticeable drop in performance from either the VHF or AIS transceiver?
    Thoughts, Opinions, Advice?
    I appreciate any input.
    Max
    I just fixed a VHF problem by removing an antenna spiltter. Go for a separate antenna if you can and remove any performance issues.
    If you absolutely can not ad any more antennas, even a small Metz type, then split your less used VHF lead coax.
    Never mess with a radio lead that could contribute to your (and/or others) safety.
  3. Maxwell
    Door County, WI
    Thanks for the input rcrapps! Everything is already exposed to pull the other wires so a dedicated antenna it shall be...
    Appreciate it!
