Click for Perko Click for Mulder Click for Furuno Click for Walker Click for Burger
Checklist for buying a new yacht
Discussion in 'General Yachting Discussion' started by hrosetti, Jun 24, 2014.
  1. hrosetti
    hrosetti New Member
    San Diego, CA
    I remember someone had developed a very good checklist to use when looking at a boat you are thinking of purchasing. I searched this forum and did an internet search with no luck. Anyone have a copy of it or a link to it?
  2. AMG
    The shortest and safest is this one;
    1. Call a Surveyor.
  3. chesapeake46
    chesapeake46 Senior Member
    That's true. especially if you're really serious.
    But reality is you're not going to call a surveyor for every boat you look at.
    Only for the one or two that pass the list the O.P. asked for.
    - Like soft decks.
    - excessive oil in the bilge
    - water stains around the windows or in the head liner.
    - filthy bilges.
    - nasty, home made wiring
    - punky stringers, if they are wood or glass over wood.
    - crumbling weather striping.
    - cracked or scaling gel coat.
    - broken ... almost anything.
    - clear lack of maintenance.
    None of these things, alone, would necessarily null the deal but if you've got a number of check marks on the list you might say " no surveyor needed, I'll move on..."
  4. YachtNewbie
    YachtNewbie New Member
    Ventura
    What does it cost for a quality survey of a used boat? Defever twin diesel comes to mind.
    Hull/boat surveyor $20 per FT +/- in South Florida, then you also have the price of an engine surveyor in addition to that.
  6. YachtNewbie
    Ventura
    Thank you; and an engine survey costs? :)
    Depends on the engines and depends on the surveyor or mechanic.....you can have twin outboards tested for around $300-400 usually.......6-12 cylinder diesel inboards could be around $1000...... it depends on how in depth you want to go as well......
  8. Ward
    Ward Senior Member
    Vancouver BC
